YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 07-21-2008, 04:45 PM   #1 (permalink)
buckz6319's Avatar
Send a message via MSN to buckz6319
Question Vibration issues
Hi I just purchased this 95 4runner 4x4 SR5 V6 and it has a vibration when it is driven.The vibration starts around 35/40 ish and seems to be worse 55/60 and when letting off the gas at a steddy speed 60 ish the vibration is there but not as bad, but when I slow down from that speed (not applying break) it vibrates reall bad.When I gas on it then the vibration smooths out some.
I have replaced the drive shaft u joints front/rear (someone said that was the prob) but no luck still vibrates.I guess not a loss cause @168,000
I have new pads/breaks turned rotors and drums, new shocks (not installed yet) gosh I just have been replacine stuff because the normal maintiance was not done.I have changed the trans fluid & filter,oil ect
I had someone tell me it could be the transfer case yoke nut loose but I don't have a pounding vibration just a kinda rolling grinding or something like that
thanks for any info on this problem I don't want to give up on this because I'm allready attached to her ....
buckz6319 is online now
Sponsored Links
To remove this ad, register today!
Old 07-21-2008, 08:12 PM   #2 (permalink)
bigarms23's Avatar
did you have the driveshaft rebalanced when you changed ujoints and and how are your yokes?
__________________
1988sr5v6 4runner with chevy axles 513 gears dual cases overall 300to1 ratio 36mtzs 5inch lift detroits
1988sr5v6 4runner with a 4inch allpro longtravel sas with detroit rear a ls in front and 33s
1985 sr5 4runner 8inch lift 39.5 boggers 529s detroits front and rear and triple transfer cases with a final crawl ratio of 2828to 1(sold)
bigarms23 is offline
Old 07-21-2008, 08:14 PM   #3 (permalink)
4Crawler's Avatar
Check all the parts of the shaft and the t-case and pinion flanges for play. Also check the phasing of the u-joints:
- http://www.4crawler.com/4x4/CheapTri....shtml#Phasing
And if that is all OK, try some of the tips listed below:
- http://www.4crawler.com/4x4/CheapTri...FixingProblems
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 07-21-2008, 08:19 PM   #4 (permalink)
TOYOTA 1's Avatar
Quote:
ive never had to have my d-shaft rebalanced after changing a u-joint..
just phase it and its good to go.
__________________
91 toyota stdrd cab short bed 22re 5spd. sas'ed hy steer. 3.5" tuff country e-z ride springs in the front. 5" allpro longtravels in the rear. es 9000's, 12" tg long spline front d shaft. k&n 35x10.50x15 boggers. cobra cb/ashtray mod, 3' firestick. etc.
2000 toyota tacoma xtra cab sr5, 3"revtek,285/70/17 coopers stt, clear tails, injen short ram intake, obx header, flowmaster, etc.
2001 toyota camry, the girlfriends,
Sierra Club sucks!
TOYOTA 1 is offline
Old 07-22-2008, 02:41 AM   #5 (permalink)
buckz6319's Avatar
Thanks guys for the info I didn't replace the drive shaft and the yokes appear to be in good condition.I had someone say it sounds like the torque converter and the vibration was there before I messed with the u joints could it be from the engine?
Old 07-22-2008, 02:45 AM   #6 (permalink)
buckz6319's Avatar
by the way don't know what phasing the shaft means can explain please
Old 07-22-2008, 02:37 PM   #7 (permalink)
buckz6319's Avatar
update guys...I took the 4runner to the shop today and they had it all day driving it burning up my gas and the result of there investigation is....they don't know they said maybe a bent drive shaft, bent short cv shaft, they thought it was coming from the timing belt maybe had lost a tooth but they said that it would be idling rough or something like that so they ruled that out. There were 3 so called mechanics smoking it over and scratched there heads said I can't tell you what to do next.....58.00 for the head scratching and i'm back to square 1.....it is a rolling issue I know and doesn't vibrate when sitting at idle....the did say that the 4runner is slow I said I know but the timing is set and maybe it just needs plugs & cap/rotor & wires?.....I know it has high miles and 31.50 x 10 new tires that dont help maybe there is a compression problem but it appears not to reall blow smoke ao anything... they did say that maybe the tranny but it shifts fine and the vibration is still there when I put it in nuteral......so any more advice?...what do I do now...
Old 07-22-2008, 02:40 PM   #8 (permalink)
904_runner's Avatar
Are the tires balanced? Just wondering
__________________
-Mike
1990 4runner SR5, 3.0 with 250K, 5-speed, 4.56 gears, warn premium hubs, Hella 500's, Rancho 9000's, 33X12.50's crappy dunlop tires, rear lock right, 4" trailmaster lift with lc coils in rear, panhard drop bracket
Soon to come: New wheels and tires, Sliders, CB.
One Day: 3.4 swap!
www.myspace.com/222948743
904_runner is offline
Old 07-22-2008, 03:04 PM   #9 (permalink)
buckz6319's Avatar
the answer to that question is yes the tires are ballanced, I feel as though I have run into a brick wall with this issue.....thanks for your input Mike... I have a question most of the 6 4runners 4x4 v6 that I drove before I purchased this one all felt like they were under powered is this normal for these 4runners and the ECT button does help...what is your opinion on this matter??
Old 07-22-2008, 03:05 PM   #10 (permalink)
904_runner's Avatar
Nah, we will figure it out! What about tranny mounts/etc..
__________________
-Mike
One Day: 3.4 swap!
Old 07-22-2008, 03:39 PM   #11 (permalink)
buckz6319's Avatar
Well Mike...I haven't checked out the tranny mounts but did look at them just a while ago with a flash light and didn't see any signs of deteration but did not jack up on the tranny to know for sure
Old 07-22-2008, 03:46 PM   #12 (permalink)
ozziesironmanoffroad's Avatar
Send a message via AIM to ozziesironmanoffroad
did you check the oil in the rear diff? check for metal shavings. also, get a friend , put the truck up on jack stands, and have your friend get it up to the vibrating speed, and it sounds bad enough that you should be able to see something wobbling. id try that. it sounds like something with your drivetrain, not your engine, since it doesnt vibrate in place. just be careful, and USE JACK STANDS DO NOT RELY ON A JACK. JACKSTANDS ALL AROUND! BE CAREFUL! these trucks seem to like to hurt us.
__________________
1988 Toyota P/U 4x4
22RE 258,000 miles on original motor
pioneer CD deck
31x10.50x15 BFG A/T
BAJA 100W lights on prerunner bumper
KC Daylighters 100W
rancho rs5000
MUD IS A VALID PAINT JOB!
If not living life to the fullest, why live it?
you just hung a vacancy sign on your ass, and my foot's looking for a room
my trucks official buildup thread
ozziesironmanoffroad is offline
Old 07-22-2008, 03:57 PM   #13 (permalink)
buckz6319's Avatar
Well I havent checked out the rear diff at all, but i'll tell u this I dont see any oil on the outside from leaking gasket...but the front diff has a small oil leak at the bottom do you think there is maybe a problem with something in the front diff because of the oil leak?......thanks Dwayne
Old 07-22-2008, 04:02 PM   #14 (permalink)
maybe, but check anyway. doesnt hurt. also lift it up on jackstands and have someone drive it up to the speed where it vibrates, and keep it there and look for a wobble. maybe you will see it, maybe not. just for godsakes be careful.
__________________
1988 Toyota P/U 4x4
pioneer CD deck
31x10.50x15 BFG A/T
KC Daylighters 100W
rancho rs5000
Old 07-22-2008, 04:24 PM   #15 (permalink)
buckz6319's Avatar
ok cool....I'll try to do that somehow this weekend in the meantime I'll just keep on trucking I hope that this thing doesn't strand me in this Atlanta Traffic but if it does then maybe my problem will be found
Old 07-22-2008, 07:44 PM   #16 (permalink)
dbcx's Avatar
Quote:
im here in atlanta too. What do your tires look like maybe you need to rotate, may not hurt to rebalance. If your starting to cup or havent rotated them that can cause some issues. Atlanta traffic kicks ass
__________________
1997 4runner. stock for now just got it
1999 z71, intake ,285bfgs,with ford keys,hypertech
1974 baja bug 2110cc dual weber 40s,rancho tranny
www.lubedealer.com/dbcox ZO#1568374
dbcx is online now
Old 07-23-2008, 02:31 AM   #17 (permalink)
buckz6319's Avatar
I have new tires purchased last week the vibration was there before the new tires .............thanks for the info
__________________
Hi Everyone I'm Dwayne From Griffin Georgia US
95 4runner SR5 RED in Color 169.000 miles so far
4x4 V-6 Vary slow!
Wild Country Tires 31s
Stock Rims
No Mods as of yet they cost a lot!
Old 07-23-2008, 04:40 PM   #18 (permalink)
buckz6319's Avatar
Ok Guys here's an update ....I new that the 4runner was slow but I didn't realize until this evening after work how bad the power really was.I purchased some tune up parts and when I got to the distributor cap and rotor it was really bad I'm talking trashed here....the contacts that stick up and make contact with the rotor 3 were & almost a 4th one were scraped away and the rotor tip was eating into my cap!....WOW!....what a drag I have never seen a cap so bad before (how does it get that way maybe from it being installed incorrectly? or just no one changing it?) Well Now I feel like I have most poneys now maybe all if I change the spark plugs which I have....
__________________
4x4 V-6 Vary slow!
Stock Rims
Old 07-24-2008, 03:59 PM   #19 (permalink)
buckz6319's Avatar
Ok listen to this...I think I have found where the vibration is by accident.I was checking the fluid in my front axel and had a flash light handy.I was looking for something in the front end that was vibrating because i feel like that's where it is coming from.I saw some really black oil kinda sludge dripping down from the drivers side and looked to see with the flash and to my surprise it was coming from the cv boot(@ the axel not the one just behind the spindel just to let u know). I looked at the boot and there was no obvious boot tear so I took my hand and pulled back on the boot and it was a seem seperation
and the cv joint is trashed don't know how long it has been that was because I just purchased it July 1st and my guess is a long time to ruin the bearings
__________________
4x4 V-6 Vary slow!
Stock Rims
Old 07-24-2008, 04:57 PM   #20 (permalink)
904_runner's Avatar
well i guess you found it. I wouldn't have even thought to check there because i swaped out for some manual hubs so my cv joints don't move when unlocked. Get those fixed, take it for a test drive and see if its gone!
__________________
-Mike
One Day: 3.4 swap!
Old 07-25-2008, 02:39 AM   #21 (permalink)
buckz6319's Avatar
Thanks Mike....I hope this will be a fix and I guess that maybe the good side to having cv's is that I can shift into 4h at any speed BUT! if I had locking hubs I would not have this problem....thanks for the help i'll update on Sunday or Monday.....
__________________
4x4 V-6 Vary slow!
Stock Rims
Old 07-26-2008, 12:14 PM   #22 (permalink)
buckz6319's Avatar
Hey mike I changed the cv shaft and it took most of the vib away and a little is still there I think its coming front wheel bearings?
__________________
4x4 V-6 Vary slow!
Stock Rims
