V6 engine replacement - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-08-2009, 07:11 PM   #1 (permalink)
i have a 94 4runner that i need to replace the engine which is a V6 3.0 3LVZE
so for my question i want to know if the v6 camry engine of the same gen would go right in my 4runner with out having to do any major mods
this is my daily driver so i can't do anything crazy here
thank you in advance for your help
3. Slow is offline
Old 12-17-2009, 07:22 AM   #2 (permalink)
toyotabull's Avatar
The 3VZ-E is a 3.0 L (2958 cc) version. Bore remains at 87.5 mm (3.4 in) but stroke is pushed to 82.0 mm (3.2 in). At introduction output was specified as 145 hp (108 kW) then later bumped to 150 hp (112 kW) at 4800 rpm with 180 ft·lbf (244 N·m) of torque at 3400 rpm. Despite sharing an engine family designation the 3VZ-E and 3VZ-FE have few parts in common.
Applications:
1988–1995 Toyota 4Runner
1988–1995 Toyota Pickup
1993–1995 Toyota T100
[edit] 3VZ-FE
The basic design is a revised 3VZ-E iron block truck motor, mated with aluminum DOHC 24-valve heads and Toyota's most advanced OBD-I control system. The upper aluminum intake plenum is of the split chamber design with Toyota's ACIS variable intake system feeding three sets of runners for both heads.
Because of the truck roots, the 3VZ-FE happens to be a physically tall motor. To make the engine fit, Toyota tilted the motor towards the firewall. This "tilt" is so severe (~15 degrees) that reaching the rear bank of cylinders is nearly impossible without first removing the intake plenum.
Parts-wise, the 3VZ-FE shares very little with the VZ engine family. The few parts shared with the 3VZ-E that are interchangeable are the main bearings, and little else. Also cams can be interchanged between the 5VZ-FE and 3VZ-FE heads(the 5VZ-FE cams have more low end torque). In a surprising twist, no electronics from other Toyota (Denso) parts are swappable.
The 3VZ-FE is a smooth running engine that was used on the Camry platform between 1992 and 1997.5 depending on the market: North America saw the engine only in 1992 and 1993 while Australia and New Zealand had it from 1992 through 1996. The engine was available in some parts of Asia and in the JDM Toyota Windom through 1997.5.
The 1992-1993 engine has 185 hp (138 kW) at 5800 rpm and 189 ft·lbf (256 N·m) at 4600 rpm. 1994+ have 200 hp (149 kW) at 5800 rpm and 204 ft·lbf (277 N·m) at 4600 rpm. There is no mechanical difference in the engine. In an embarrassing move, Toyota inadvertently created an engine competing with the more performance oriented 7M-GE (200 hp) and 2JZ-GE (225 hp) installed in sportier, more luxurious cars of the time. Because of this; the stock ignition timing and fueling was noticibly detuned. The power spread of the 3VZ-FE is wide, having 100% torque between 2500–4600 rpm, with power trailing off by 6000 rpm. Stock redline is 6600 rpm, and the ECU's fuel/ignition cut is 7200 rpm.
Though harder to find in good used condition in North America (unless imported), the 3VZ-FE is a fairly common V6 in most parts of the world, after having a good lifespan in popular models. They are cheap, simple, have few problems, and have become a semi-popular subject for engine swaps (particularly into the mid-engine MR2).
The 3VZ-FE has a larger forged steel crankshaft and large cast rods. They can handle double the stock power output, although forged pistons & rods are recommended. A few nitrous and turbocharged examples match or exceed 450 hp (336 kW) on both the stock engine and engine management with a piggyback chip controlling fuel & ignition.
Applications:
1992–1993 Toyota Camry
1991–1996 Toyota Windom/Lexus ES300
Hopefully this helps you, good luck here's the website I pulled it from http://en.wikipedia.org/wiki/Toyota_VZ_engine
__________________
1985 x-cab 20R-22R 33-12.5
www.whenshtf.com
I would rather explain to the judge why my 16 year old daughter shot an intruder, than explain to the jury why it took 5 days of torture for my daughters killer to die
"If you are mad as hell and aren't gonna take it anymore, grab your rifle and head outside. If you're the only one with a rifle screaming like a maniac, go back inside. It isn't time yet."
toyotabull is offline
Old 12-17-2009, 07:24 AM   #3 (permalink)
toyotabull's Avatar
Ofcourse it posted twice, sorry
__________________
www.whenshtf.com
Old 12-17-2009, 08:28 AM   #4 (permalink)
brian2sun's Avatar
Now would be a good time to do a 3.4 swap.
__________________
'97 4Runner SR5 3.4L 4x4 * 200K Mile Club * Trail & Snow Rig
3" Suspension Lift - 883s/891s, 1" 4Crawler BL, OME Comfort Shocks, 255/85R16 Bighorn M/Ts on 16x7 (4" BS) Cragar Soft 8 Wheels
Rear ARB Locker , 4.88s, Sliders, ARB Bullbar, CBI Rear Bumper w/ Tire Carrier (on the way), No Sway Bars, No ABS
'05 Honda CR-V 2WD LX * 29+ Hwy MPGs * D.D.
brian2sun is offline
Old 12-17-2009, 08:35 AM   #5 (permalink)
904_runner's Avatar
That is indeed an option..
If you can ref that motor swap in your area then go for it..
Otherwise throw another 3.0L in it and you won't have to worry about smogging it.
__________________
Mike
1990 4runner: 3.4 swapped, 5-speed, sas'd, Rear leaf swap, front high pinion W/ARB, 30 spline longfields with chromo hub gears, 5.29's, 39.5" iroks on Beadlocks, Armor'd
Duals coming soon: Pending funds
My build thread
http://www.yotatech.com/f152/904_run...thread-158746/
http://www.treadlightly.org/
http://www.pirate4x4.com/tech/billav...ery/index.html
904_runner is offline
Old 01-02-2010, 01:17 PM   #6 (permalink)
this is off subject
i have a 96 lexus es 300 that i have around 40k in and prob the sickest in the area. im doing a motor swap or replacement really and need the torque specs for the pistons and if the are torque yield. the motor is the yota 3vzfe 3.0 any help would be great
jalvinses300 is offline
Tags
1993, 200, 3vzfe, 4runner, camry, engine, es300, hp, lexus, motors, replacement, swap, toyota, toyoyta, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
