| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Tranny bolts to block
#2 (permalink) |
Call toyota. They have all the bolts you need, or at least can give you the sizes.
__________________
Zach '83 Shortbed 4x4 L52HD Rebuilt & Mostly Stock |
#3 (permalink) |
Some of the bolts are M12x1.25 length I am not sure with out measuring
The others are M10x1.25 as well as the starter The clutch slave cylinder is M8x1.25 I hope that helps.
#4 (permalink) |
bell housing bolts are 17 or 18 mm
starter bolts are 14 mm and the slave cylinder is 12mm the 22r has 4 bolts for the bell housing 2 in the top and 1 on each side. good luck
__________________
85 toyota rancho lift 33 in tires on 15X8 steel 270 lift cam and flat tops Those who do not learn from history are doomed to repeat it, or they're showing up their friends. Again! |
| Tags |
| bellhousing, bolts, missing, toyota, tranny, transmission |
