toyota will not turn sharp
Old 05-30-2008, 01:54 PM
rpgarry's Avatar
After sas my 89 toyota will not turn very sharp is that just how it is? 4'' lift 33'' tires trail gear high steer 1.50'' wheel spacers 85 toyota axle
Old 05-30-2008, 02:14 PM
ozrunner's Avatar
My 86 cant flip a u-turn in a pretty wide street so i guess thats how it goes. Your mods probably arent helping either.
Old 05-30-2008, 02:19 PM
4Crawler's Avatar
Make sure the steering is adjusted properly such that it turns from steering stop to steering stop.
Old 05-30-2008, 02:26 PM
bruzer's Avatar
Mine seems to turn ok. Did you make sure the steering box was centered before you installed the pitman arm? And like 4crawler said, check your steering stops.
Old 05-30-2008, 02:27 PM
Elvota's Avatar
x2.
Plus, does it turn one direction "sharper" than the other?
Old 05-30-2008, 02:57 PM
rpgarry's Avatar
Originally Posted by Elvota
x2.
it turns just as sharp each way but its about 1'' away from hitting the steering stops.
Old 05-30-2008, 03:21 PM
Kaleb's Avatar
My buddy had the same problem when he bought an SAS'd Toyota pickup. Turns out the guy that did the swap got the passenger side steering links mixed up. The drag link was where the tie-rod was supposed to be, and the tie-rod was where the drag link was supposed to be. After he switched it he could turn much better, and much easier.
Old 05-30-2008, 03:54 PM
rpgarry's Avatar
thanks but thats not it and I don't see how you can get them mixed up.
Old 05-30-2008, 04:35 PM
4Crawler's Avatar
Put the front end up on jack stands and see if you can do a little detective work to find out why. Maybe something is binding up or not working right. Also, you can try disconnecting the drag link and see if the steering box is turning farther without it hooked up.
On my '85 I was playing around with the steering to see why it was not turning all the way (not a stock axle). In my case, I found it was the drag link that was too short. As I cranked the rod ends out I got more steering throw. But they were too far out to hold well, so I welded a pair of nuts (RH and LH threads) to the ends to make it longer. With the extra length, I was able to get the steering all the way to the stops.
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: toyota will not turn sharp
