Toyota Running Rich/Running Lean? NEED HELP!
Old 05-18-2007, 12:03 AM
mrboyertown's Avatar
Question Toyota Running Rich/Running Lean? NEED HELP!
I have a 94 Toyota SR5 V6 Automatic Pickup with 200,000mi. All together the truck runs good....no major problems. The only minor problem is that when the truck idles, or is even revved at a constant rpm with no load, it has a small lope to the engine.(The best way to describe it is that the truck vibrates with a little shimmy, nothing major, but I know the engine should be running a little smoother) Ive been getting a check engine light with the codes 2-5 and 2-6. In my manual it tells me that 2-5 code means the truck is running rich and the 2-6 code means the truck is running lean? I have already replaced the 02 sensor which wasn't cheap and before I go any further I was wondering if anybody else had a problem like this? The manual says it could be injectors, fuel pressur, ingnition sys., coolant temp sens., air flow meter and so on. The truck runs perfect except for the shimmy, and the fuel mileage isn't the best. You cant even really notice the lope in the engine while driving, only when the motor isn't under a load. Any Ideas?
Old 05-18-2007, 12:05 AM
Toyota Running Rich/Lean? Need Help!
Old 05-18-2007, 12:15 AM
Bunta Fujiwara's Avatar
https://www.yotatech.com/forums/show...t=22RE+running
hope that helps... there's a lot of good replies in there.
I had the same trouble, but your problem may be different...
there are a great many possible combinations that can cause a problem like the one you are currently experiencing.
Old 05-18-2007, 12:19 AM
put in the specific category for better results.
although I suppose newbie tech works just as well...
Ichneumon
09-27-2015 04:21 PM
luke0927
07-02-2015 10:49 AM
sonic concepts
07-01-2015 02:33 PM
Jake28296
06-27-2015 07:24 AM
94hiluxZE
06-22-2015 10:42 AM
Quick Reply: Toyota Running Rich/Running Lean? NEED HELP!
