Timing belt question
Old 08-19-2015, 06:58 PM
Scatpac's Avatar
I accidentally moved the passenger side cam pulley to the 3:00 O'clock position when putting on a new timing belt. The driver's side cam pulley remains at the 12:00 O'clock position as does the crank shaft pulley. Question can I rotate the passenger side cam pulley counter clockwise back to 12:00 or can I rotate the pulley clockwise 1 rotation. Thanks in advance for the help. The engine is a 3.4l 5vz-fe
Old 08-20-2015, 02:08 PM
Scatpac's Avatar
I will reply to my own post. Talked to a Toyota mechanic today. The engine is a non interference type as I knew so you can spin the cam pulley either direction to line up the timing marks. So I will go with that.
Old 05-25-2017, 06:47 AM
djohn24's Avatar
Hey Scatpac, how did your engine run once you made the adjustment?
bigjstang
08-25-2021 12:41 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Quick Reply: Timing belt question
