the term "3rd member"?
Old 08-31-2009, 01:47 PM
wilshire's Avatar
What exactly is this? Is it synonymous with differential? Or does it apply to something more, like the term differential is limited to a specific mechanism while '3rd member' refers to the whole thing with the housing and everything?
Also, why is it called this? Is there a 2nd member somewhere?
Old 08-31-2009, 01:58 PM
83's Avatar
Think porn. Like Goldmember, except this would be more like a threesome.
No it's the differential. Front or rear. Honestly, and someone will certainly speak up, I'm not positive where the term comes from, but it's the gear set in the front & rear axle.
Old 08-31-2009, 02:03 PM
[N8]'s Avatar
Actually quite the opposite. The differential would be the whole thing with the housing & the 3rd member would be the removable center section.
Old 08-31-2009, 02:05 PM
Matt16's Avatar
Its the idea of a differential AND housing that is separate from the axle housing. WIth domestics (Ford 9" aside), the differential housing is part of the axle housing so you have to work on the diff in axle housing. Toyotas and most other imports have a differential housing that bolts into the axle housing:
third member
bolts into axle housing
domestic axle/ diff
Here is a third member that has been taken apart from the diff.
Old 09-11-2009, 09:27 AM
Ron Helmuth's Avatar
thanks Matt16 that is most helpful with the pictures and all-
thanks wilshire for not being afraid to ask. I never understood myself until now.
Flightguy
10-02-2015 05:34 PM
voiddweller
10-02-2015 07:47 AM
tylermx71
09-29-2015 08:49 PM
dbollier123
09-29-2015 05:23 PM
taraf
09-25-2015 02:57 PM
Quick Reply: the term "3rd member"?
