taking off panhard rod for coil install
Old 04-17-2007, 04:49 PM
BamaT4R's Avatar
How hard would it be to put the panhard rod back on if I take it off during the install of new coils? It would let the diff droop enough to make the removal and install of the coils easier correct? Then I can just jack up the diff and reinstall the panhard? Thanks for the help.
Old 04-17-2007, 04:52 PM
AuburnRunner's Avatar
I took off the panard when putting on my LC coils... Putting it back in was just a matter of finding the right height of the jack and a little muscle... Oh and War Eagle
Old 04-17-2007, 05:12 PM
olharleyman's Avatar
you should be able to change the coils without disconecting the panhard. I put custom built 6" coils in mine and all i did was use a spring compressor then got a friend to stand on the tire for the little extra needed to drop the old ones out and the put the new ones in I did the one at a time is all.
Old 04-17-2007, 05:22 PM
ltbulldog23's Avatar
I unhooked the panhard bar to install OME coils in the rear of my '97. No problem to reconnect it... let the rear axle hang, seat the coils, then put a floor jack under the axle housing and raise it until the bar realigns with the connecting bracket. Shimmy the original bolt in place and you're good to go.
Good luck!
Old 04-17-2007, 08:23 PM
FredTJ's Avatar
Disconnect the shocks and the sway bar and you'll most likely have no trouble replacing the coils.
Fred
Old 04-17-2007, 10:05 PM
SacRunner's Avatar
I agree with every one above, there's no need to remove the panhard to install new springs; but if you do remove it, install a panhard drop from downey, 4crawler, or pro-comp (I think they're all pretty similar).
I wasn't lucky enough to find the "right" axle height using a jack to get the holes to re-align, but a come-along hooked between the frame and axle did the trick (I was working on this one solo, if you have a buddy just have him push the axle over)
Old 04-18-2007, 05:48 AM
tc
tc's Avatar
When I did mine, we undid the panhard.
1. It didn't make much if any difference
2. It was a PITA to get back on
The "fat friend standing on the brake drum" is the most effective technique. If you can't do it that way, I would suggest undoing the sway bar before disconnecting the panhard.
Old 04-18-2007, 08:28 AM
SteveO's Avatar
I recently helped a friend installer taller coils on his 3rd gen 4Runner. We did have to disconnect the pan hard bar to get the Driver side coil in place. Connecting it, I used a ratchet strap to pull the axle towards the passenger side of the frame. This made it easy to connect back up.
Old 04-19-2007, 01:37 AM
BamaT4R's Avatar
thanks for all the replys. I ended up taking it off, it did help, and yes, it was a PATA to get it back on.
bigjstang
08-25-2021 12:41 AM
sandyota
02-04-2021 11:16 AM
09-04-2015 09:27 AM
bryan34w
07-06-2015 05:53 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: taking off panhard rod for coil install
