| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
T-CASE shifting problems?
__________________
FOR SALE 1986 Ext. Cab 4x4, rebuilt 22R, 5spd, 31x10.50 X-Terrains FOR SALE 1992 SR5 FO RUNNA V6, 5 speed, 4in. trail-master lift, 33x12.50 BFG muds, 4.56 gears!!! and an IMMACULATE interior..yes..you should be jealous "Its still a toyota man.. Dont deprive it of its capabilities.." "If you can read english, Thank a teacher...If you can speak it, Thank a soldier!!" Kelli Ruark-2009 |
#2 (permalink) |
Super Moderator-Sponsoring Member
Staff
Pretty normal sometimes if you are not on a flat surface with no "tension" on the driveline. You might need a new shifter seat.
One is a single u-joint the other is a double u-joint. Easy enough to replace.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. |
#3 (permalink) |
thanks ALOT....yea...now that i remember...i was always on a hill or small incline when it would do this...
Ken,
__________________
#4 (permalink) | |
Staff
Quote:
Good luck.
__________________
#5 (permalink) |
mine is hard to put back in 4 hi so i just let it roll backwards in neutral and then it shifts just fine.
#6 (permalink) |
Location: I live in Red Bluff ca. Right by the Sacramento river
Every single toyota Ive ever been in with the gear drive transfer case, is hard to put back into 2wheel. Ive seen beat up ones that did it, and show quality ones also. You just have rock it back and forth. Hell, almost all 4x4s with manual transfer cases take some finesse. As far as your vibration. My driveline has a lil play, but excess will cause it to wobble. Sounds like you need new u joints. Good luck!
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| shifting problems | clint | 86-95 Trucks & 4Runners | 0 | 11-05-2007 09:16 AM |
| transfer case shifting problem | cig4059 | 86-95 Trucks & 4Runners | 5 | 02-06-2007 09:32 AM |
| shifting problems | toy4whatever | 86-95 Trucks & 4Runners | 3 | 01-16-2007 07:18 PM |
| top shifting t-case shifter | exoman | The Classifieds GraveYard | 1 | 06-05-2006 06:43 AM |
| Dexron in manual transfer case and 4wd shifting problems? | runethechamp | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 10-19-2005 09:27 PM |
