Thread Tools | Search this Thread | Display Modes |
#26 (permalink) | |
Quote:
Please post up some references to your numbers so that we all know that you aren't simply buying bad rope. ![]() Fred |
#27 (permalink) |
Autos are nice in rocks and also in sand. Often on a dune, you can shift a manual without losing too much speed. An auto, however, you can.
I had a stick and when I think about going back, then needing dual cases, drive shafts.... or just run an auto and be done with it, the auto wins. sure it sucks up power to operate but it's worth it. The wife likes it too which makes it easier to go wheeling when she wants to go as bad as youdo. You do need to two foot with the auto which is not hard to learn. Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper. www.sdori.com |
#28 (permalink) | |
Quote:
Learning to use two feet with the auto is much easier to learn than learning to use the three feet that you need with a manual ![]() ![]() Fred |
#29 (permalink) |
ya im going to soon ... i still have 4 months till i get my license but i still occasionally drive it.
__________________
95 toyota 4runner sr5 limited, bj spacers and procomp coils on 33-12.50 toyo open country M/Ts |
#30 (permalink) |
i 2 foot my auto all the time and it still sucks...the fact that the torque converter sucks and is slipping dosen't help...it really dosen't matter what auto you have with big tires and rock crawling soon your TC WILL SLIP...then it's all down hill...also on a side note hot haveing to worry about the trans over heating is good
__________________
89 4runner 3.0L, 5spd swaped like what ya see...check my build http://www.yotatech.com/f116/my-very...runner-143762/ Don't Follow me, you won't make it "Wheeling the piss out of it" AND "DD"ing it since 2005 |
#31 (permalink) |
I've driven a 5 speed(86) and auto(92) and the auto is far better on the trail and on the freeway.
Now back to the original topic. I have a 92 4Runner with Eibach springs in the rear and Downey torsion bars resulting in 1.5"-2.0" of lift over stock(cost about $250). With 32s and no sway bars I get a little rubbing at all four corners in extreme situations. Replacing the stock rear bumper and tow bar with a Marlin rear bumper lifted the rear an additional quarter inch. It is my understanding that the OME springs, torsions and shocks with rear spacers and ball joint spacers will allow 33s with little or no rubbing. |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| wanted suspension lift kit for a 1990 4runner | mrnick1979 | Items Wanted | 0 | 10-12-2007 06:24 PM |
| Please help w/OME suspension kit! | 03-4RunGalactic | 03+ 4Runner/GX470, & 05+ Tacomas | 1 | 11-06-2006 05:32 PM |
| sas kit or pre 85 lift kit? | oz31p | The Fab Shop | 10 | 06-07-2006 07:21 AM |
| In search of a 2WD lift/suspension kit. | sorefeet | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 05-20-2005 09:13 PM |
| Downey suspension kit | Tom | Offroad Tech | 56 | 04-02-2004 02:20 PM |
