YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > Newbie Tech Section
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 12-21-2009, 06:56 AM   #1 (permalink)
Personal Sales Rating: (0)
Stuttering at 3500 rpm in 02 4runner
Hi, I replaced the plugs and wires about a week ago and I am getting stuttering around 3500 rpm. I am also getting a hard start once in awhile, especially after having the key on. It starts eventually but kicks out a bunch of white smoke. I took it to Midas to get it looked at, but did not have half a day to leave it there. They thought it sounded like a bad injector. Is there a way to check if an injector is bad? How easy is it to replace an injector?
milehi is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 12-21-2009, 08:53 AM   #2 (permalink)
brian2sun's Avatar
White smoke does not usually indicate a bad injector, it usually indicates a head gasket leak. Smell your exhaust when you first start it and see if it smells sweet. Any water coming out the tailpipe (besides after startup for a few minutes - that is normal)? It sounds to me like Midas is making wild guesses, so bring it to a full service shop and have them look at it. They can test your injectors, but it sounds like you should have them do a compression and a leak-down test. How is your coolant level in the overflow and the radiator? Any milkshake in the oil or coolant?
__________________
'97 4Runner SR5 3.4L 4x4 - Lifted on 35s, Geared, Dual Locked, and Armored
'98 Tacoma Regular Cab 2.7L 5-speed 4x4 - Bone Stock DD
brian2sun is offline
Old 12-22-2009, 10:16 AM   #3 (permalink)
zach@sparkplugs.com's Avatar
milehi, you've probably already done this, but double check your wires, make sure that they're definitely fitting onto the plug, a lot of times you'll feel a nice little snap when it geos onto the plug. Are they gapped correctly? Also, what part number are your plugs?
__________________
www.sparkplugs.com
Come be our friend on Facebook
www.facebook.com/#/pages/SparkPlugscom/80872868814
zach@sparkplugs.com is offline
Old 12-22-2009, 11:25 AM   #4 (permalink)
Elton's Avatar
elton hostler
Send a message via AIM to Elton Send a message via MSN to Elton
i hope you used ngk or denso plugs and wires these toyota's dont care for anything else
__________________
07 Tundra d-cab limited 5.7L 4x4 was my moms r.i.p 3/19/11
98 4runner SR5 3.4L 5spd 4x4 E-Locker sold 10-2-11
91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06
97 honda civic lx 4dr ls vtec
Elton is offline
Old 12-22-2009, 05:07 PM   #5 (permalink)
brian2sun's Avatar
The dual electrode plugs are not supposed to be gapped before install. The gap on our plugs are .43 or .44 from the factory, but each electrode's gap is 1/2 that so .22 per side. I remember reading on NKG's site (and on threads here on YT) that if you try to gap these plugs you'll have problems.
__________________
Old 12-22-2009, 05:46 PM   #6 (permalink)
Elton's Avatar
elton hostler
yea ive changed the plugs twice on my truck using factory denso's with no problems just putting them in right from the box
__________________
Elton is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
01, 2000, 2005, 3000, 34l, 3500, 4runner, 4x4, 91, civic, honda, rpm, runner, start, starts, stutter, stuttering, stutters, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
