stumbles and surges at accelloration
Old 10-13-2014, 02:54 PM
guttbucket's Avatar
81 pickup 22r weber carb
when i give it fuel my engine stumbles and surges, losing all power and takes a second to smooth out. it idles great. my first thought was fuel system. i checked all the lines, got new filters, cleaned my carb thoroughly, even tried a new fuel pump. same story. so elliminating fuelk system i turned to air. i've had a weber carb for over a year with no trouble, but figure some of the vacuum lines i had plugged might be the issue. so i totally de smogged! removing EGR, Reed valve, and air injection to exahust. looks better, same problem. so i think it has to be spark? im stumped and without 4 wheel drive. any advise or ideas would be greatly appriciated.
Thanks.
Old 10-18-2014, 08:03 PM
guttbucket's Avatar
Im pretty sure it was a loose ignition switch ground wire. Before I found it, I replaced my distributor and the problem changed. It would surge while idling and run smooth when given fuel. weird
Firefightersink15
11-23-2015 10:32 PM
83yotastockR
11
11-10-2015 06:54 AM
Ditch Doc
10-27-2015 03:20 PM
Gurr
09-12-2015 09:51 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: stumbles and surges at accelloration
