strut question (I'm confused) - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-12-2007, 10:45 AM   #1 (permalink)
Sandman's Avatar
Is the stock front shock on my 97 4runner also called a strut? Or, is the strut a separate component. The strut is built into the shock's housing, right?
When shopping the web for new front shocks for this truck, I often see pics of shocks that don't have the strut housing...what do you do with those?
__________________
90 4runner 4cyl-5spd, detroit lockers - 5.29 gears,All Pro hd rear coils, 25mm torsion bars, 2" bl,Warn manual hubs, 33s
99 4runner 6cyl auto
RIP (hit a deer) 97 4runner V6-5spd 4x4, e-locker with 2wd/4wd mod, isr & airbox elbo mod
Sandman is offline
Old 07-12-2007, 10:58 AM   #2 (permalink)
eric-the-red's Avatar
Yes, the fronts are struts, aka coilovers, or coilover shocks. The actual shock is in the middle of the assembly. To replace the shocks the struts have to be disassembled, which requires a spring compressor.
eric-the-red is offline
Old 07-12-2007, 11:20 AM   #3 (permalink)
Sandman's Avatar
thanks for the quick reply
-so, after disasembly, I should be looking at 3 separate parts?
-coil spring
-strut
-shock
Let's say I buy new bilstein shocks for the front:
Am I replacing just the shock and re-using the original strut, or does the new shock housing have the strut built in so that I am down to 2 parts instead of 3?
__________________
Sandman is offline
Old 07-12-2007, 11:26 AM   #4 (permalink)
Elton's Avatar
Send a message via AIM to Elton Send a message via MSN to Elton
no theres only 2 parts the spring and the strut
__________________
My Truck 98 4runner SR5 3.4L 5spd 4x4 E-Locker Mods
Mom 07 Tundra d-cab limited 5.7L 4x4 auto
sister 92 pickup SR5 X-cab 3.0L 5spd 4x4
Papa 89 Pickup SR5 X-cab 4x4 3.0L 5spd/98 4runner SR5 4x4 auto 3.4L
R.I.P 91 4runner SR5 4x4 3.0L 5spd Totaled 5/13/06 My Wreck
Elton is offline
Old 07-12-2007, 11:29 AM   #5 (permalink)
Elton's Avatar
here this should give u a idea
top ones are struts
__________________
Elton is offline
Old 07-12-2007, 11:40 AM   #6 (permalink)
Sandman's Avatar
Thanks Elton.
I've only had this truck a few weeks and don't even have a Haynes manual or FSM for it yet. I can't seem to find any write-ups regarding strut replacement -should I assume it's the same as a lift install?
__________________
Sandman is offline
Old 07-12-2007, 11:48 AM   #7 (permalink)
Elton's Avatar
the fronts are a snap i done all the shocks on my truck with very basic hand tools took me around a hour to take out the struts heres a how too http://www.4rnr.net/suspension.html
__________________
Elton is offline
Old 07-12-2007, 12:32 PM   #8 (permalink)
Sandman's Avatar
thanks - I'll post up my results after I get my shocks & do the install.
__________________
Sandman is offline
Old 07-12-2007, 06:22 PM   #9 (permalink)
It is a little confusing but it is a shock and you treat it like a strut for replacement. The diagram shows a part called suspension support. This piece is held down by the nut on the top shaft of the shock which is why you need a spring compressor to remove the shock. If you just undid the top nut the entire force of the spring would be released and that piece would disapear through your roof (or teeth). The only hard part is lining up the 3 bolts in the piece since they attach it to the truck with the lower bolt mount. If you don;t get it right then you recompress and turn the shock a little and try again. Some people have reported success with attaching the 3 top bolts and using a bar to turn the bottom into position.
GhostriderTx is offline
Old 07-13-2007, 04:45 AM   #10 (permalink)
GSGALLANT's Avatar
4Runners don't have struts.
A strut combines the primary function of a shock absorber (as a damper), with the ability to support sideways loads, and eliminates the need for an upper suspension arm. This means that a strut must have a more rugged design, with mounting points near its middle. Struts are typically only used on vehicles with unibody design.
4Runners (3rd gen and up) have double wishbone suspension, with coil-over shocks.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 07-16-2007, 08:53 PM   #11 (permalink)
Sandman's Avatar
Well, I did all for corners on Saturday, and it is all much clearer now. One front shock was completely shot, but the others weren't too bad. The front was pretty easy compared to the rears! The upper nut was "rust-welded" on each rear shock, but I was able to snap them clean off.
__________________
Sandman is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
2001 Taco Prerunner Strut Question ElwayLite 95.5-2004 Tacomas & 96-2002 4Runners 0 07-27-2006 09:55 AM
Confused Noob Question Poopshute 95.5-2004 Tacomas & 96-2002 4Runners 3 03-01-2005 02:57 PM
quick question regarding strut spacers zedex 95.5-2004 Tacomas & 96-2002 4Runners 11 12-04-2003 12:29 PM
Mcpherson strut question Paul H. Off Topic Talk 0 08-19-2003 06:07 PM
Strut Question Yochdog 95.5-2004 Tacomas & 96-2002 4Runners 2 02-23-2003 06:33 PM
2009 InternetBrands, Inc.
