Steering Relay Rod Recall - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-14-2006, 09:27 PM   #1 (permalink)
Steering Relay Rod & Idler Arm issues
I have seen posts regarding the Steering Relay Rod recall that many dealers are not doing front end alignments (toe in) because of bad Idler Arms. Is it common that the Idler Arm fails with 94 4Runners? I bought a 94 4Runner with 95k miles (orig owner). The truck never saw a dirt road. I have to bring it in for the recall but want to know if I should do front end work first... I was thinking outer tie rod ends and the Idler Arm. Also, I have seen complaints that the Toyota Idler Arm and general oem replacements other that Moog are a problem. Any thoughts? QuietGiant
QuietGiant is offline
Old 06-15-2006, 10:51 AM   #2 (permalink)
Quote:
Usually the stealership will agressively try to solicit work you would have to pay for while they have you car apart for the recall. You might consider getting some simple stuff done, as long as they don't try to screw you. But, it's probably a better deal to just make them do the rod and nothing else.
As for idler arms, man I hate that thing. With my lift (BJ spacers with 26mm T-bars and 33-12.50 TrXuS M/T's) the thing would keep an alignment for MAYBE 2 weeks. Those damn plastic bushings in there just can't take the heat. So, I decided to go hardcore and got an invincible Chrome-Moly Idler Arm from Total Chaos Fabrication (you may recognize them for their extended A-arm "Caddy" lift for 2nd gens). It's a little expensive ($299) but it's super strong, and bolts straight in (you just have to drill the center link to 5/8"). I highly recommend it, because my 4Runner keeps its alignment agressively now, even off-road. Highly recommended!
http://www.chaosfab.com/toyaccess_4wd.html
I'm 1/100th of the way to getting a Caddy Gen-2 from them!
__________________
Brian
1998 4Runner SR5
mastacox is offline
Old 06-15-2006, 12:03 PM   #3 (permalink)
mt_goat's Avatar
Yeah and what most won't bother to tell you is the bushing can be replaced in the idler arm. Unless the idler arm is bent it's probably just the plastic bushing that is worn out. IIRC when I replaced my bushing it was maybe a $5 part.
__________________
~Dale~
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000.
mt_goat is offline
Old 06-15-2006, 01:48 PM   #4 (permalink)
I considered having a new bushing pressed instead of buying a replacement idler arm. Are there still machine shops that press bushings? I havn't seen one in years? At the moment, I am in Phoenix AZ. Do you have a recommendation as to where I can get one pressed here? Mastacox, I see you are from Tucson (not exactly next door).
Old 06-15-2006, 02:24 PM   #5 (permalink)
joatmon's Avatar
You don't need to have anyone press them in. They're plastic. You can push them out with a screwdriver and push them back in with your fingers and a flat surface. I just did this this weekend. The thing that took the longest was filling it back up with grease. Here's a write up: http://www.4x4wire.com/toyota/maintenance/idler/
__________________
1991 4Runner SR5 V6 5-Speed 4X4 230,000+ miles
Things I need to fix/repair: Fan Clutch, Bent Spare Tire Carrier.
Things I've added/fixed/repaired: Centerforce Clutch, Centerforce Heavy Flywheel, Reman R150F tranny, Leaking steering gear box, Rearend sag, Suspension Bushings, Shocks, Ball Joints/Tie Rods, Leaking valve covers.
Things I need to add: Radio w/ CD, CB, Fog lights, Driving lights, Rear aux lights, Seat covers
joatmon is offline
Old 06-15-2006, 04:55 PM   #6 (permalink)
tc
tc's Avatar
I would take it in first. There's a fair chance that they will cover the replacement of the idler arm, pitman arm, and tie rods (they did on mine!)
Be sure to read the ENTIRE stickied thread at the top.
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 06-15-2006, 10:19 PM   #7 (permalink)
Thanks for the "heads up" TC, on the sticky thread and Joatman, on the Idler Arm maintenance post. VERY helpful. I will do new bushings this weekend and call for the recall appointment. I am in Phoenix AZ at the moment with the 4Runner. I saw a post on the 14 page thread where Right Toyota in Scottsdale was used and the member was happy. I'm on the other side of Phoenix closer to Bell Toyota (North Phoenix) and Larry Miller Toyota (Peoria). Has anyone had experience with either of these dealers? I would like to go to the dealer yielding the least brain damage to the customer... QuietGiant
PS. TC, I notice you have a 96 SS Impala (Personal Cop Car). Nice ride. I had one but, I sold it last year with 18k orig miles. I refered to mine as my "4200LB Corvette"
Old 06-16-2006, 09:33 AM   #8 (permalink)
tc
tc's Avatar
I would like to go to the dealer yeilding the least brain damage to the customer... QuietGiant
__________________
tc is offline
Old 06-24-2006, 06:51 PM   #9 (permalink)
Yeah take it in first, thing is the dealer makes a pretty good deal on recalls because the main factory pays for the work so they are getting paid to begin with. I have had my 934WD PU recalled twiice with good service both times.
burpwagon is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
GOT MY RECALL DONE (Steering Relay Rod) keithguts 86-95 Trucks & 4Runners 21 05-01-2007 05:03 PM
Steering rod relay recall Bejiita 86-95 Trucks & 4Runners 3 03-08-2007 05:57 PM
Steering Rod Recall? ken.vs.ryu General Vehicle Related Topics (Non Year Related) 16 02-18-2007 12:33 PM
steering rod recall Riverboy 86-95 Trucks & 4Runners 9 04-17-2006 09:14 PM
Steering relay rod replacement safety recall notice cccp 86-95 Trucks & 4Runners 12 03-09-2006 10:25 PM
2009 InternetBrands, Inc.
