Standard/Metric Brake Line Fittings
Old 03-06-2011, 06:05 AM
BajaRunner's Avatar
Alright so I stripped both the threads and shoulders off my brake line fitting trying to replace the flex hose in the rear. Donno how it happened, but whatever.
Call Toyota for a replacement flare nut fitting (10x1.0mm) and of course they laugh at me saying that I can't just buy a fitting, I need to buy the whole rear assembly for $25.
I'm certain I have dealt wit this before, but I can't remember if I used a 3/16" standard fitting or if I went to a brake specialty shop. I need the car by Monday and the only brake specialty shop is closed on Sunday and about 30 mins away.
If I just put on the 3/16" standard fitting, will it work? I've got a flare tool already...so I 've done it before but can't remember
Old 03-06-2011, 07:38 AM
greencactus3's Avatar
autozone carries the metric fitting you need
Old 03-06-2011, 07:51 PM
BajaRunner's Avatar
Yep went to Autozone and they had them. Sweet.
Old 03-06-2011, 07:52 PM
BajaRunner's Avatar
So I find it interesting this was moved to Newbie tech. I tried searching the "normal" tech forum and didn't find anything.
BajaRunner's Avatar
What also is interesting that the mod had time to move the post but not answer the question? Thanks!
Old 03-07-2011, 04:54 AM
habanero's Avatar
Not every mod is going to concretely know the answer to your question.....and the part you were looking for is pretty basic as is the question 'bout standard or metric so newbie tech might be a good place for this even though you're not one.
Just hazarding a guess.
09-04-2015 09:27 AM
CanRunner
07-20-2015 01:29 PM
rondogracing
07-14-2015 07:00 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Standard/Metric Brake Line Fittings
