Something Fishy - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-08-2009, 04:24 PM   #1 (permalink)
Plate between Flywheel and Crankshaft?!?!?!?
I bought an '89 4Runner (22RE) which broke down on me about 3 days after purchasing. I dropped the transmission to find the flywheel bolts are all completely out of their holes! needless to say the bolts were stripped so i get me a new set, go to remount a new flywheel and I cant get any thread engagement on the crankshaft. My first thought is that the threads are all stripped too badly for the new bolts to engage. However, i have also noticed there is a circular plate between my crankshaft and the flywheel kind of like a spacer. The holes in the plate are not threaded at all and the plate is pressed onto the crankshaft. After looking at the Haynes manual and the Toyota repair manual and after searching the forums, i cannot find this circular plate at all. I am thinking this plate is why the bolts came out in the first place. See the pictures below for what i am talking about.
I am not the best mechanic in the world so i would appreciate if someone could tell me if this plate is even supposed to be here. Or, if its not supposed to be here, what would it be used for?? I am now going to rent a pulley puller to pop this thing off. Would i be mistaken if i did not put it back on when i reassemble?
f000ooo is offline
Old 12-09-2009, 06:34 AM   #2 (permalink)
zlathim's Avatar
I am totally shooting in the dark here, because it has been a long time since I've had the flywheel off a 22re.
I am wondering if that spacer is an application for an automatic transmission flex plate that is not needed when running a manual transmission and flywheel.
Do you know if the PO did a motor swap recently?
Just an idea, but BUMP for someone who knows more about this and can shed some light on your situation.
__________________
Do you think Einstein walked around thinking everyone was a bunch of dipsticks?
Idiocracy (edited for family friendly viewing)
zlathim is offline
Old 12-09-2009, 04:46 PM   #3 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Search for iamsuperbleeder and his 22R-E build thread for some GREAT pics. Might help you.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R-VP.
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Claws, 4.88's, TrueTrac rear. Rear disk kit/tcase e-brake. Addicted Offroad bumper/XRC8000. Stubbs sliders. Snorkel. Pics
'06 4Runner Sport 270/65R17 BFG All Terrain KO's
SEARCH n00bs
Quote:
Originally Posted by kiyobrown View Post
funny, new parts get mentioned first, wife who has been gone mentioned second. Priorities, priorities. I like where your head is at.
BigBluePile is offline
Old 12-15-2009, 02:29 PM   #4 (permalink)
runnerboyy's Avatar
neither the flexplate or the flywheel are the same between a manual and an auto.
__________________
1987 runner, sas, built housing, rebuilt motor, swapped from auto to manual with dual cases and a twin stick, detroit rear, locked front, home brew front bumper, winch w/ synthetic rope, sliders, tg dual crossmember skid plate, 4.88s, 35" km2s, and the start of an exo.
runnerboyy is offline
Old 12-15-2009, 03:34 PM   #5 (permalink)
Quick update for those interested... i took the weird plate thing off and put up the transmission with a new clutch and flywheel (and new bolts of course). I try to start it and the engine turns, there is a spark, but it never catches. i have not connected the driveshafts but the clutch engages and disengages properly. It looks like i am getting no fuel. There does not seem to be any problem with removing that plate. The starter engages just fine and like i said the engine is now turning.
Hate to hijack my own thread but can anyone see why i wouldnt be getting fuel after flywheel bolts come off?
f000ooo is offline
Old 12-17-2009, 06:40 AM   #6 (permalink)
toyotabull's Avatar
you have everything electrical reconnected?
__________________
1985 x-cab 20R-22R 33-12.5
www.whenshtf.com
I would rather explain to the judge why my 16 year old daughter shot an intruder, than explain to the jury why it took 5 days of torture for my daughters killer to die
"If you are mad as hell and aren't gonna take it anymore, grab your rifle and head outside. If you're the only one with a rifle screaming like a maniac, go back inside. It isn't time yet."
toyotabull is offline
Old 12-17-2009, 03:59 PM   #7 (permalink)
I troubleshot the electrical system found that the EFI fuse keeps blowing. The O2 sensor connector was melted which seems to be a common problem. I repair that and the engine starts! However it only runs for a second and my EFI fuse keeps blowing. Since fixing the O2 sensor, my diagnostic started working again and i pulled a code 31 (MANIFOLD AND/OR AIRFLOW METER SENSOR SIGNAL CIRCUIT). Im either gonna start looking at that closer tonight or perhaps this weekend but has anyone had a common problem affecting the AFM electrical?
Update: Checked the AFM using 4crawlers site and found the AFM to fail the static test. I plugged the AFM back in and did the bypass cheap trick http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump and the truck started and did not die. I then removed the jumper and the truck started and again did not die. Im off to get a new AFM. I hope this is the end of my problems.
f000ooo is offline
Old 12-17-2009, 04:17 PM   #8 (permalink)
MuddfreaksOffroad's Avatar
you have a short somewhere if your blowing a fuse! HUNT IT DOWN MAN HUNT IT DOWN haha. but glad you got it all workin for the most part tho
__________________
MUDDFREAKS OFFROAD Toyota Tech and Fab/ Muddfreaks a NWG.
MY TRUCK - getting a 4x4 yota
MY DADS - 1989 built 22re 4x4, 4in sus, 3in bl, 35x14.5 superswamper boggers, custom paint, 4.88s and Detroit locker in rear.
"Toyota's, there everywhere u wanna be!"
"Toyotas will go anywhere and everywhere u wanna go!"
MuddfreaksOffroad is offline
Tags
22re, automatic, flexplate, spacer, toyotq, trasmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
