Rough Idle In 91 V6
Old 04-21-2008, 07:39 PM
91YotaExcab's Avatar
Rough Idle In 91 V6
HELP ME!! I cant figure out why my tuck is running so crappy... i have done changed plugs wires cap and rotor. the fuel filter and both belts and it is still idle really bad and doesent run right till it gets to about 2000 rpm. the truck only has 97k miles does anyone have any ideas?
Old 04-27-2008, 07:49 PM
colsoncj's Avatar
I would look into a throttle position sensor and its position. I'm not really familar with the V6's, but the symptoms youre experiencing could be attributed to a bad TPS on a 22RE.
Old 04-27-2008, 09:16 PM
toytech76's Avatar
I wouldnt look at that first. Check your compression. Tune up items and compression are the very first things you need to check on a 3.0 before anything else
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
TACOJO
11-27-2015 05:26 PM
markwink
08-18-2015 12:38 PM
Quick Reply: Rough Idle In 91 V6
