Replacing fan clutch fluid with oil.
Old 03-20-2011, 07:05 PM
AmpedRunner's Avatar
I keep hearing that when the silicone fluid in the 22re fan clutch goes bad you can replace it with 20/50 wt motor oil and a little lacquer thinner. I know it sounds crazy but since my fan clutch is really starting to slip, I was wondering if this method had any viability in it.
Thanks for any input!
Old 03-20-2011, 07:12 PM
Janderson31R's Avatar
why thinner?
Old 03-20-2011, 07:15 PM
SoCal4Running's Avatar
No idea about that BUT if you have a hobby store near by you can get synthetic shock oil there for way less than the stealership.
I have 4000, 5000, 8000 and 10,000 weight oils on hand for my RC cars and it works perfect in the fan clutch too.
Old 03-20-2011, 07:17 PM
I have no idea but it says it on this website here It claims it's not the best option but works. I'm fine with ordering new silicone fluid but I am curious as to if this redneck method actually works
Old 03-20-2011, 07:18 PM
Good to know! thanks
smthwsn357
12-04-2023 02:08 AM
mskalmus
05-28-2017 07:51 AM
coryc85
09-09-2015 06:24 AM
Kalihi,HI
07-09-2015 04:29 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: Replacing fan clutch fluid with oil.
