| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
recovery strap??
__________________
2000 Toyota 4runner auto, 4x4, elocker, budbuilt skid, Sonoran Steel 7.2, 265/75/16 Yokohoma Geolanders AT-S Just call me "T" |
#2 (permalink) |
That's plenty strong, probably 2x as much as your vehicle weighs, or more. I use straps rated for 5000lbs. and haven't broke one yet. My truck, with me in it, fully gassed up and loaded for bear, weighs around 4000lbs. D-shackles are handy.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 03-09-2007 at 07:55 PM. |
#3 (permalink) |
i snapped a 20k lb tow strap when pulling my friends mountaineer out. i went over a bump and when he hit it it just snapped so i want to upgrade to the rubber band type. thats probobly your best bet wormhole. theyre strong but wont snap when jerked. too bad i dont know what brand or from where to buy one... any ideas?
__________________
http://www.cardomain.com/ride/2233170 |
#4 (permalink) |
i carry 2 a 2" x 20' 20,000 lbs and a 3"x30' 30,000 lbs (and an industrial grade 30' chain) . i have found that you can have a strap too long as well as to short. do not get the kind with metal hooks, they are for flat towing on the street, nothing else. If you only by one, buy a good one, its worth saving for an extra week or 2.
good luck and this is an extremely important purchase, choose wisely. the wrong strap could leave you stranded or dead..
__________________
1989 SR5 V6 5sp 4RUNNER. -> MOST VIEWED 1ST GEN ON YOTATECH! www.toyotatrailriders.com Wheeling Texas Style |
#5 (permalink) |
it would most likely work but its most recommended to use one rated at or above 20,000 pounds. i'd go 2" at the skinniest, 3" would be better but unless the loops are folded, you can't stick a 3" in your hitch receiver
__________________
-David 2000 Taco TRD Access Cab v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights Pictures |
#6 (permalink) |
also, make sure its a RECOVERY strap, not a tow strap. recovery straps are designed to stretch, tow straps arent.
__________________
#7 (permalink) |
I had a set that I ripped the hook off of one end a couple weeks back that i got at autozone for $20 bucks and I think they were less rated than the one you've been looking at! I've pulled out 5 people this past winter so that might be the cause but that's plenty strong. good luck, it's a good investment!
__________________
97' 4RUNNER SR5 4x4 Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears 2in. 4crawler BL, SS Diff drop, Custom welded drop bar Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod Wheels & Tires:315 16x9's on MOTO METALS Lights:Silver Reverse Glow Gauges, Hella 500's Armor:Trailgear Sliders, Taco ARB "Sounds stupid. . .sign me up!" |
#8 (permalink) |
Yeah, I've seen straps snap like that with a shock load. I've been real carefull to apply steady pressure to avoid breakage. Only thing I haven't seen break is a chain. There too heavy to ride with me, but I got lots of em.
__________________
Sonoran Steel Early IFS Truss Your IFS is SPINELESS without it SonoranSteel.com I'm Cuckoo For YOTA Trucks! Last edited by MudHippy; 03-09-2007 at 08:12 PM. |
#9 (permalink) |
do it man. i think arb makes one but im sure its very expensive as is anything with their name on it but im sure itll hold up
__________________
#10 (permalink) |
Thanks for the replies guys. Ya, I know all to well not to get the ones with hooks. Too many experiences with those while down on a navajo indain reservation for 11 months.
Anyhow, a member over at ttora referred me to this http://www.ttora.com/forum/showthread.php?t=61339 I think I'm going to go with the 3" (in between the other two) and the reciever shackle. I was hoping to get one today because I'm going to scout out an area tommorrow for a yotatech/ttora/pirate4x4/customtaco (who ever comes from those) run on the 24th of the this month. If I order one know I should have it by then.
__________________
#11 (permalink) |
I got a KEEPER 6"x30' strap and it's friken awesome! It has done more than I ever thought it would! Of course its a bulldoser strap. If its good enough for them it has to be great for me. It ran me 130.00 but of all the 20/30 dollar ones i've bought I could have got this one 2 or3 times over. I also have some 10 ton Clevises/ Shackles off of a hummer from the Marine's. leathal combo!
#12 (permalink) | |
Quote:
__________________
#13 (permalink) |
Well, I went ahead and order a 3 x30 recoverery strap and the steel receiver bracket:
http://www.wheelersoffroad.com/tacotowstrap.htm
__________________
#14 (permalink) |
ARB snatch strap...there is no other choice for me. its like a big ribber band
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#15 (permalink) |
Staff
Yeah My ARB has so been worth the $125 I paid. Because it will tell you (by changing colors) when it has been abused and is about to fail.
__________________
Molly aka Lysmachia 93 4 Runner SAS (Tippy) - All Broken in Junk Yard Goodness Get your 4x4 VIDEO pr0n here |
#16 (permalink) |
Thanks wheelers off-raod
UPS came today and bought me a gift.
![]() $77 including shipping. The 3" strap might be much for the amount of use it will get but better safe than sorry.
__________________
| Tags |
| 40, 4runner, big, buy, good, houston, pulling, receiver, recovery, snap, snatch, strap, straps, texas, top, trucks |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Recovery/tow strap | Chapman88SR5 | Offroad Tech | 15 | 10-28-2006 12:30 AM |
| Looking to buy a recovery strap… | bike4miles | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 10-25-2004 01:44 AM |
| Recommend recovery strap | L33T35T 4Runner | Offroad Tech | 9 | 07-09-2003 05:09 AM |
| I need a recovery strap | UKMyers | 95.5-2004 Tacomas & 96-2002 4Runners | 21 | 01-06-2003 05:19 AM |
