Rear third, replace seals? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-30-2007, 07:00 AM   #1 (permalink)
crolison's Avatar
Hello,
I am going to be putting in a locker in a few weeks, me and my friend will be pulling the third and taking it to be professional set up. I was wondering do we need to replace the axle seals after we pull out the axles a bit? If so which seals would we need to replace the inner or the outer?
Thanks,
Chris
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns
armor
locked
lifted
heavy SOB
broken front and rear swaybars
My Profile..
crolison is offline
Old 10-30-2007, 07:49 AM   #2 (permalink)
GSGALLANT's Avatar
Inner seals are what you should be concerned with the most. They are cheap and easy to replace once the axles are out, so I would replace them (If you decide not to replace them, don't let the axles rest on the seals that are currently installed when you pull the axles out a bit. This will deform the seal. Pull the axles out completely until the third is re-installed).
Take a look at the outer seals to ensure they look good (what you can see of them, anyways.) You would have to press off the bearings to replace the outers, and the critical ones are the inners to keep the diff fluid from leaking out.
__________________
2002 4Runner, Auto-A340F, 3.4L, 4.30 Gears
TJM T15 Front Bumper & Warn M8000, 4xInnovation sliders, Sonoran Steel 1.2 Lift, Toytec LCA Skids, Tundra Brake Upgrade (231mm), Extended rear diff breather, Deckplate Mod, Andymod, Dual batt setup with Optima blue top aux battery, Hardwired 1000W inverter, Aux fuse box, Full time power to 12V plugs, Yaesu FT7800R Radio, "4-air" system for airing up/down tires.
2004 Camry LE - stock (and will stay that way)
1993 4Runner has been sold
GSGALLANT is offline
Old 10-30-2007, 12:35 PM   #3 (permalink)
tc
tc's Avatar
Quote:
x2 and learned the hard way
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 10-31-2007, 06:39 AM   #4 (permalink)
crolison's Avatar
thanks guys. i am going to order some inner seals from the stealership and pick them up on the way out of town.
__________________
armor
locked
lifted
heavy SOB
My Profile..
crolison is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear axle seals rgs20inophir 95.5-2004 Tacomas & 96-2002 4Runners 18 08-23-2007 02:51 PM
Rear Axel Seals SwampThing 86-95 Trucks & 4Runners 2 03-18-2007 08:18 AM
Leaking rear axel seals, rear bearing slop TahoeEd 95.5-2004 Tacomas & 96-2002 4Runners 0 12-15-2004 09:53 PM
Rear Seals Again!!!!! - Need Advice WatsonMD 95.5-2004 Tacomas & 96-2002 4Runners 7 11-12-2003 12:43 PM
Need help with rear axle seals David 95.5-2004 Tacomas & 96-2002 4Runners 36 09-09-2003 08:07 AM
2009 InternetBrands, Inc.
