Rear Differential Drain & Fill Plugs - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-31-2011, 07:41 AM   #1
4ever4running's Avatar
Angry Rear Differential Drain & Fill Plugs
So this past weekend I decided to replace the oil in my front differential, transfer case, and rear differential. On Saturday I sprayed down all the nuts/bolts with PB Blaster and let them soak overnight. I started with the front differential, no problem. Then I moved to the transfer case, again, no probelm. Then I got to the rear differential, and nothing. The drain and fill plugs will not budge! I even had a neighbor help me and the two of us still couldn't get either of them to move . After about an hour of wrestling with the bolts , I gave up and just spraying it with more PB Blaster and I figured I would try it again sometime this week because I was worried that I was going to strip the bolt and make the problem even worse. So, does anyone have any tips/tricks that I can use to get the darn bolts off?
4ever4running is offline   Reply With Quote
Old 01-31-2011, 07:44 AM   #2
waskillywabbit's Avatar
Always remove the "fill" plug first.
Big impact. Zip. Off.
Get new plugs.
Tighten with ratchet snug.
:wabbit2:
waskillywabbit is offline   Reply With Quote
Old 01-31-2011, 08:07 AM   #3
snobdds's Avatar
I just did this over the weekend and mine were pretty frozen on there too. I just hit it with PB blaster and broke out my 24 inch breaker bar. Had to put quite a bit of force on it but it went...so did my knuckle into the leaf spring.
Man I hate the smell of gear oil. It almost makes me sick.
My breather was also rusted shut, so I ordered two new ones from the dealer. Don't forget about those.
snobdds is offline   Reply With Quote
Old 01-31-2011, 08:10 AM   #4
xxxtreme22r's Avatar
6pt socket and nothing else, 1/2" breaker bar and an impact socket is best. 3/4" if you must. Impact gun is also possible if you have one. Before using impact gun, I suggest you find yourself a new plug first.
Mine was hell to pop as well. I don't think the PO ever checked it.
xxxtreme22r is offline   Reply With Quote
Old 01-31-2011, 09:47 AM   #5
Yeah I have been using a 6pt socket the whole time because I know the bolt is soft and has a tendency to strip if you use a 12pt. I have been using a 3/4" breaker bar with a 1/2" adapter. After work, I think I am going to pick up a 1/2" breaker bar and a steel pipe to use as an extension and see if that works. Unfortunately, I don't have access to an impact gun but I think that is going to be my last resort
Old 01-31-2011, 02:14 PM   #6
also try tapping on the bolt head as well with a hammer. Not smashing it just some light taps.
Old 01-31-2011, 02:15 PM   #7
This one time, at band camp
Staff
DeathCougar's Avatar
If you strip it, use a hammer and a cold chisel to work it loose.
DeathCougar is offline   Reply With Quote
Old 01-31-2011, 02:46 PM   #8
aa1911's Avatar
still can't get my rear diff on the 4runner loose. I've PB blasted it, torqued on it with cheater pipe (6pt socket as well, 1/2" drive), torched it, hit it with a hammer.... it almost looks like it's part of the diff itself, won't budge even with a little chisel action. I'm tempted to get a BFDrillbit out and solve this the power tool way... need to rebuild/regear soon anyway...
better luck to you!
aa1911 is offline   Reply With Quote
Old 01-31-2011, 02:53 PM   #9
highonpottery's Avatar
i'd give it a couple more days soaking in PB blaster and then try a long cheater bar for leverage. might not be a bad time to install some low-profile magnetic drain plugs before you fill it back up.
highonpottery is offline   Reply With Quote
Old 01-31-2011, 03:04 PM   #10
boristheblade is offline   Reply With Quote
Old 01-31-2011, 03:15 PM   #11
wyoming9's Avatar
Red face
If you need heat a propane torch is not going to do the job.
You need a fuel gas / oxygen of your favorite.
wyoming9 is offline   Reply With Quote
Old 01-31-2011, 03:21 PM   #12
FleshThorn's Avatar
My rear diff drain plug was kind of rounded when I bought and it is defiantly rounded now. Anyways, I ended up sucking all of the gear oil out with a syringe. Maybe in the Spring when I don't need 4x4 I will take time to remove and replace it. I am thinking a blue flame wrench and an extractor. Some must take the quality of a Toyota pickup so much for granted that they didn't bother to perform routine maintenance or so it seems.
FleshThorn is offline   Reply With Quote
Old 01-31-2011, 03:23 PM   #13
snobdds's Avatar
Quote:
better luck to you!
Yea either do your drill bit idea or weld a new bolt on there and go at it with a 1/2 in impact.
Old 02-03-2011, 09:33 AM   #14
I will be sure to try that. Thanks!
Quote:
Hopefully I can get it off without stripping it, but it was pretty unwilling to move so I will have to see what happens this weekend...
Quote:
That is exactly what I have been diong. I have been coating the bolts in PB blaster every day for this past week. Hopefully that is enough time for it to work its magic. Where can I get the low profile drain plugs?
better luck to you!
Man I hope I don't have to resort to that to get them off. Thanks!
Old 02-03-2011, 09:50 AM   #15
Quote:
I got mine from Inchworm, but you can get them from pretty much any vendor who sells transmission, transfercase or differential parts: Marlin, Inchworm Gear, etc. They're only a couple bucks each and don't protrude from the diff like the standard hex bolts do, but instead have a lower-profile head and use an allen socket for r/r. This way you can still get it out after you've beat it up real good on some rocks.
Old 02-03-2011, 09:54 AM   #16
Hmmm that seems like a pretty good idea. Do you know of any disadvantages of going with a low-profile plug like that?
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
FS[PacSouthWest]: 2- 8"3rd members:4.88 ratchet lockers,new setup kit, rear axle rebuild kit,diff armor jerusry Axles - Suspensions - Tires - Wheels 1 10-19-2015 06:28 PM
Here come the bearings.... Gamble_STi 86-95 Trucks & 4Runners 2 07-07-2015 08:54 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
New AC Questions (Not the same old ones) HRDC0R19 86-95 Trucks & 4Runners 3 07-05-2015 07:43 PM
Tags
2001, 4runner, differentail, differential, drain, fill, hard, location, low, plug, plugs, profile, rear, removing, time, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
