| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Radiator Hot and Cold
#2 (permalink) | |
ill bet its clogged.
undo the hoses leave the cap on, and then put a garden hose in the top hole. water should run out the bottom at the same speed its going in the top. (to a point). just something to check.
__________________
91 Toyota "built not bought" Quote:
#3 (permalink) |
May have not waited long enough for the radiator to get as warm as the engine, especially if it was cold out side. Thermostat only opens till the the coolant drops just under the opening threshold. So if the rad had cold coolant the thermostat wouldn't stay open long. So a shot of hot coolant rushes into the rad thermostat closes, heat rises. And boom your rad now has two temperature "zones" until more hot coolant rushes in. Take it for a spin, watch the temp gauge you should be fine.
I've got an aftermarket temp gauge and can tell right when the thermostat opens, when its cold outside the temp instantly drops after it opens.
__________________
http://www.youtube.com/watch?v=rqtr_RvR3sY Balljoints for sale. Open to trades and offers. http://www.yotatech.com/f11/ball-joi.../#post51278784 |
#4 (permalink) |
Are you sure you got all the air bubbles out of the system??
Did you burp the system?
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 250k |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |idler arm brace|hella E-codes| Marlin armor |SS IFS brace | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
