Questions re 3" lift on '04 tacoma 4x4 access cab v6
Old 05-18-2006, 11:59 AM
D Barrette's Avatar
Need 3" lift on '04 tacoma 4x4 access cab v6...help! No idea...
I need some clearance for some 285 kumho's that I put on. I don't know anything about lift kits and was told this was the place to find out. Help please!
Old 05-18-2006, 12:16 PM
D Barrette's Avatar
Lift '04 tacoma
Help. I want to put 3" lift on my 04 tacoma access cab v6 trd. I don't know where to start. Any advice would be very appreciated.
Old 05-18-2006, 12:21 PM
EWAYota's Avatar
try www.ttora.com and also try here
Old 05-18-2006, 01:14 PM
Tacoclimber's Avatar
First off, welcome. DJ's right - a quick search for "3" lift tacoma" or similar will yeild a lot of good results that will help you make an informed decision. A lot of it depends on what kind of money you have, what you're doing with your truck, etc. Search it up, and get to reading. You will walk away thankful that you did, because not only will you know what you're looking for, you will be educated about it, too. Good luck!
Old 05-18-2006, 01:35 PM
WATRD's Avatar
Helpful search strings:
tacoma 3" lift
tacoma spacer lift
tacoma coilovers
tacoma aal
tacoma add a leaf
tacoma shackle
or, look here; http://www.customtacos.com/tech/index.php?article=137
You will be an expert in no time.
Old 05-18-2006, 02:44 PM
D Barrette's Avatar
Is 3" enough?
I have 285/75 R16 for my 2004 tacoma. Will 3" of lift be enough clearance for these? Shout back at me if you know FOR SURE. Thanks!!
Old 05-18-2006, 02:45 PM
tc
tc's Avatar
There are a variety of options. Your front suspension is the same as the 3rd generation 4Runner. Check out that forum on here for more info.
Do NOT use blocks in the back. You'll end up with broken springs. Either add-a-leaf (AAL) or a new, rearched spring pack. Deaver and Alcan are really good.
More info on Tacos at www.ttora.com
Old 05-18-2006, 02:51 PM
tc
tc's Avatar
One thing I know for sure is you should have put all of these together in one thread...
285/75-16 = 33x11.50 right?
One of our TTORA guys has a 99 running 33x10.50 with about 2.5" suspension lift + 1" body lift, so I think you might rub a little with only 3", but I don't know for sure.
What wheels? How much backspacing?
Old 05-18-2006, 02:53 PM
Bob_98SR5's Avatar
D Barrette,
You need to put your questions all into one thread if they are related...and they are. So please stop creating new threads.
merging...
and there are some great links here. please read them before asking more questions.
Bob
Old 05-18-2006, 02:54 PM
WATRD's Avatar
First, a tip... instead of starting multiple threads about pretty much the same question, start one thread if and only if you have attempted to find your answers by searching first. All three of your threads could be answered by five minutes of quality time with the search button. That will make people more likely to help you and your questions easier to stomach for those who have already heard these questions 14 thousand times.
As to your question, Tacoma's vary from truck to truck, but odds are good you are going to experience some rubbing onroad with 3" and 33's and likely A LOT of rubbing off road. It will depend upon a lot of things, like wheel offset, driving style, terrain, etc. but if you want tires that will fit properly, 32's or 265/75's are a better sure bet for just 3" of lift. Sure you can put 33's on there, but what good are they if they limit your flex even more than the IFS already does and if they rub if you look at them wrong.
Again, this has been covered a zillion times already... hint... hint...
WATRD's Avatar
Doh! You guys jumped in while I was typing...
At least we are consistent.
Old 05-18-2006, 03:02 PM
D Barrette's Avatar
I was told to expect these kind of responses. Sorry guys. I don't ever use these message board things. Kind of figuring it out as I go along. I just got this price quote from a place in Vancouver called North Shore Offroad. 'Revtek 3" lift system with 2 x ProComp rear shocks (KITTAC3A-REV) : 659.00 ' Does that sound like a good price? I HATE being clueless like this. Thanks for your patience and help.
Old 05-22-2006, 08:48 AM
Mangone's Avatar
Smile
If you run a Google search you can compare prices pretty fast. But, make sure you check out the vendor section. We like to offer discounts to YotaTech Forum members.
Old 05-22-2006, 08:53 AM
HUTCHSTACO's Avatar
check out cornfed suspension and toytech
TURBOrunnerNM
07-22-2015 11:01 AM
Cplmike
07-08-2015 08:47 PM
God's Bounty Hunter
07-08-2015 12:54 PM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: Questions re 3" lift on '04 tacoma 4x4 access cab v6
