Power steering belt 86 runner - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 08-18-2009, 01:41 PM   #1
heatt69's Avatar
1986 toyota 4runner...How to u replace the power steering belt on a 22re? I have three pulleys and looks to me no tensioner...I found out how to change it, now I am not sure how to tell when it is tight enough??? Any help would be great...It seem's to have bit of a wistle, now that I finished changing that belt, comming from the power steer pully..I might have it to tight, no idea....Oh 22re motor, no A/C
heatt69 is offline   Reply With Quote
Old 08-18-2009, 03:01 PM   #2
4Crawler's Avatar
There should be a tensioner pulley, top of photo, just left of center:
4Crawler is offline   Reply With Quote
Old 08-18-2009, 04:50 PM   #3
heatt69's Avatar
Yeah I found how to change it but it doesnt seem self ajusting, is it?
Old 08-18-2009, 04:56 PM   #4
4Crawler's Avatar
Not self-adjusting, you need to loosen the center bolt, then turn the adjuster bolt on the end of the bracket to move the pulley in and out. I like to tension the belt so there is maybe 1/2" of deflection in the middle with thumb pressure. With a new belt, you may need to re-tension it after a while as the new belt will stretch a little in use.
Old 08-19-2009, 12:56 PM   #5
heatt69's Avatar
Thanks alot that help's alot
Old 09-16-2009, 06:10 PM   #6
I need to replace the PS belt and the alternator belt on my 89 4Runner w/22R-E. I have the manual and I could not figured out the steps to replace these belts. For the PS belt, can you just loosen the Idler Pulley center bolt per above and use the adjuster bolt on the Idler Pulley to take off and replace the belt? If not can you please give me the steps.
For the alternator, do I need to take off fan? and is there a belt adjusting bolt? If yes, where?
Any help will be deeply appreciated.
cmarina98 is offline   Reply With Quote
Old 09-16-2009, 06:15 PM   #7
4Crawler's Avatar
Quote:
Yep, that is about it.
Belt usually just fits over the fan, may need to do that a blade at a time. No tensioner bolt, that is the alternator itself and it's slotted bracket:
Old 09-16-2009, 07:12 PM   #8
Thank you. Got the PS belt per your description. Now I have another stupid question on the alternator. I loosen the top nut on the slot bracket. But I am having a tough time to loosen the bottom bolt. I tried to push the alternator towards the engine, but can't. In your experience, which is the easier direction, working from the top or from the bottom. I have tried both. Thanks.
Old 09-16-2009, 09:14 PM   #9
4Crawler's Avatar
Usually need to loosen both the bolt in the slot and the bolt at the bottom of the tensioner bracket *and* the bolt at the base of the alternator to get it to pivot. If it has been there a long time, it can be stuck pretty solid, but you need to push the alt. towards the block to loosen the belt. To tighten mine, I use a pry bar between the alt and block then pull on the bar with a ratchet strap (not too hard, but enough to tighten the belt) and then snug up all 3 bolts before taking off the strap and bar.
Void Dwellers 1995 4Runner 4WD SR5 voiddweller 86-95 Trucks & 4Runners (Build-Up Section) 19 05-02-2016 10:10 PM
Steering problems help please Bamripzit 95.5-2004 Tacomas & 96-2002 4Runners 1 07-19-2015 02:17 PM
Steering problems help please. Bamripzit Offroad Tech 5 07-13-2015 08:21 PM
small block 350 yota 1badyota350 84-85 Trucks & 4Runners (Build-Up Section) 1 06-28-2015 07:50 AM
Tags
1997, 22r, 22re, 4runner, belt, change, changing, power, pulley, repair, replacing, runner, steering, toyota, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
