YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > Newbie Tech Section
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 12-31-2006, 09:54 PM   #1 (permalink)
Personal Sales Rating: (0)
navyredneck's Avatar
Polyurethane, good or bad
What is confusing me is the good vs bad of polyurethane.
Polyurethane is bad for control arm bushings (unless you're a street racer) because the stock rubber mounts absorb more of the constant off-road shock. That's kind of the feel I get from many threads.
Polyurethane is good for replacing body mounts when you do a bodylift because it helps minimize sway and vibrations.
Polyurethane is bad for anti-sway bar bushings because it resists movement more than rubber, making your truck flex less offroad.
I used some polyurethane on my OME shocks when I installed them and as a result, I can sometimes hear squeaks coming from the back of the 4runner, particularly on rough roads. Will there be more squeaks from the poly body mounts if I replace them?
__________________
1985 pickup std cab 4wd rebuilt 2.4L 22r by Oregon Engine Rebuilders, RV cam, oversize valves, Weber 34 DGEC, 8k on engine,5 speed, OME shocks N93/N85 front/rear, rear diff breather, Durabak interior, Summit proportioning valve, SR5 cluster mod, 3" RB body lift, warn winch brushguard with harbor freight winch, custom rear bumper, FROR floating rear axle with pickup disc brakes all around
navyredneck is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-01-2007, 11:23 AM   #2 (permalink)
mt_goat's Avatar
Poly will squeak more than rubber but if you lube them up good with silicone grease (I use dielectric grease mixed with graphite powder) they are fairly quite.
I have poly upper control arm bushings and poly sway bar bushings and poly leaf spring bushings with no squeaks.
__________________
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG KM2, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, TJM T-17, Warn m8000.
mt_goat is offline
Old 01-01-2007, 12:31 PM   #3 (permalink)
Personal Sales Rating: (2)
4Crawler's Avatar
Poly only squeaks when there is motion between the part inside the bushing and the bushing itself. If poly body mounts squeak, that means there is something moving (like the body) and that is not good. With the body mount bolts properly tightened, there should be no squeaks. I've run poly bushing for about 9 years now and never had a single squeak:
- http://www.4crawler.com/4x4/CheapTri...shtml#Bushings
Poly is stiffer than rubber and flexes less. Keep the poly greased (I use graphite loaded wheel bearing grease on mine) and it won't squeak. I find it also last longer, I have had a set of rubber spring eye bushings disintegrate in one wheeling trip. Poly bushings last me many years and they seem to flex just fine:
Click the image to open in full size.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad - YotaTech discount code
Gettin'Off 4WD Club
4Crawler is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2002, arm, bad, bar, body, bushing, bushings, control, good, graphite, mounts, poly, polyurethane, squeak, sway, tundra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
T100s - the good and the bad Tacoma Dude 99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 16 08-22-2009 04:08 PM
oil additives, good, bad? itsmeagain5789 86-95 Trucks & 4Runners 14 12-25-2006 06:56 AM
The Good, the Bad, and the Ugly payyourtoll Off Topic Talk 22 09-05-2006 09:30 AM
3 good tires, one bad. BAZ Offroad Tech 3 11-11-2005 08:13 AM
Good trip gone bad. OicnaiC 95.5-2004 Tacomas & 96-2002 4Runners 13 07-23-2003 05:23 PM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
