pilot bearings for 22re for at or standard trans
Old 09-04-2013, 10:30 AM
piccaso's Avatar
hi im a newbie and have an 1985 4x4 pickup just acquired with all the motor parts in the back took it to a mechanic and had it all reassembled turns out the block that was used had a standard tranny and mine is an automatic and the pilot bearing is sticking out approx. 1/2 inch, upon checking the ring gear for the automatic is a lot thinner than the standard and cannot be bolted tight am I going to have to change this bearing or can it simply be driven in farther
Old 09-04-2013, 10:46 AM
snobdds's Avatar
That was painful to read. No punctuation and one big long run on sentence, not to mention vague.
Want to try that again...
Old 09-04-2013, 11:09 AM
85toy4runner's Avatar
I would take the bearing out , you wont need it . you have an automatic that doesn't require one , only manual trans needs this pilot bearing
Old 09-04-2013, 12:32 PM
piccaso's Avatar
Great thanks for the help, its much appreciated
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
88sasturbotoy
08-11-2015 01:56 AM
calderp
07-27-2015 09:58 AM
shadowbirdie
07-21-2015 10:38 PM
Quick Reply: pilot bearings for 22re for at or standard trans
