| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
oil pressure
#2 (permalink) |
are you going by the factory gauge in the dash? these are prone to failure. get a mechanical gauge and test that way. mine read below "low" on the factory gauge and is in reality perfectly fine.
Also possible the oil pickup is clogged....
__________________
90 3vze 4x4 runner mostly stock. custom isr mod, cherry bomb turbo muffler 31x10.5 Coursers with stock 4.10s hehe. custom 4runner a$$ sag :( and 1 extremely dirty lebra. (no hood scoops) |
#3 (permalink) |
thanks, i have both kinds of gauges on it and neither were registering any kind of pressure and when i was investigating i took the oil filter off and no oil had been circulated thru it??? and when i put the motor back together the pick up was totally cleaned in the parts washer that is why i feel real confussed
#4 (permalink) |
did you prime the pump?
__________________
#5 (permalink) |
Yea i was just about to ask that. Always primp the oil pump if its new. IS THERE OIL IN IT! Leaking oil? Where did you buy the pump and what kind.... Got the correct filter? You rebuilt the motor did you pump the strainer back in? It clogged? Oil goes from pan, pump, filter, and then bearings and gallerys..... so yea...
__________________
My current: 1986 Toyota 4runner SR5 EFI 4cyl 2.4L 22RE 5-Speed 242,000 Miles 95% Stock __________________ (Still working on restoring her) My old: 1988 Toyota 4runner SR5 EFI V6 3.0L 3VZ-E 5-Speed 302,000 Miles All stock (sold)______________ (Was my fastest truck i miss her...) My old: 1989 Toyota 4runner Non-SR5 EFI 4cyl 2.4L 22RE Automatic 231,000 Miles (sold)______________ (was my quietest and slowest yota.) |
#6 (permalink) |
well now i feel like a real moron i have never had to do that so how would you suggest i prime it?
#7 (permalink) |
Fail....hey slug is that a hood scoop?
#8 (permalink) |
Pour oil into the pump and move it around alil to get it lubbed and ready for 1000000000's of miles.
__________________
#9 (permalink) |
Should i do this through the relief valve on the housing or should i pull the pump off and lube it before i re install it?
#10 (permalink) |
how would you prime the pump? the relief valve on the housing or take the pump off and lube it before reinstalling.
#11 (permalink) |
Melkar how come your poimanently stuck on 5 posts?
#12 (permalink) |
Haha that's no hood scoop, thats an extremely dirty bra on the front of the truck! I'd take it off the truck, but it's been on so long the damage is done. (thanks PO)
__________________
| Tags |
| 3vze, oil, priming, pump, relief, toyota, truck, valve |
