| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Newbie with questions
#2 (permalink) |
Welcome to yotatech. Here are a few things to consider:
1) You may want to post this in the newbie tech section, it will get more responses there. 2) If you are going to drive the truck on the highway the 5 speed tranny is worth the swap otherwise leave the 4 speed in there if it is in good working order. 3) Go 5.29 only if you are not going to go bigger than your current 35's. If you are planning bigger than 35's change your gears and axles and axle housings accordingly. 4) The outlaw 527 cam from LC you mentioned is not only the worst cam they offer for rockcrawling, it would also not work well with a turbo set up. To rockcrawl you want a LOW off idle torque curve, the outlaw cam doesnt kick in until 3000 rpm. You want lower lift with forced induction set ups because of the extra pressure in the cylinders and for a smoother idle, the outlaw has the highest lift of any 22r/re cam LC makes. You shouldnt ever get above 5,000 rpm or so rockcrawling for any reason, the outlaw goes up to 8000 rpm (you wouldnt even be using the upper end of the cam). I would go with one of there turbo camshafts as they are speced to go specifically with a turbo set up. Good luck with getting everything together. Also remember on about 90% of your questions the search button is your friend. Thomas |
#3 (permalink) |
thanks for the help. I have seen some turbo cams, they have less lift, and if i remember correctly less intake/exhaust duration too. and you are saying 5.29s are enough. The reason why i mentioned 5.71s is for a better crawl ratio, but i might change the transfer case gears.
#4 (permalink) |
lc isnt the only one w/ parts look around there are a few that sell quality. Try 22re.com among others
__________________
Piston selection and Camshafts.Who knew? |
#6 (permalink) | |
Quote:
Thomas |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newbie with a few questions | Sunpowered | Pre 84 Trucks | 5 | 04-21-2008 02:49 PM |
| Newbie questions???? | Brownie | Newbie Tech Section | 4 | 08-23-2007 04:32 AM |
| Newbie w/ Questions... | BrentNClemson | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-06-2005 12:19 PM |
| Newbie questions | mbeck | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-04-2004 10:00 AM |
| newbie questions | willljzab | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-03-2004 12:43 PM |
