| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Newbie questions????
#2 (permalink) |
Adjust the A/C idle up valve, not the idle screw on the throttle body:
http://www.4crawler.com/4x4/CheapTri...ne_Pix/11.html ![]() O2 sensor can be tested, observe ~8 0.2-0.8 volt swings in 10 seconds w/ engine running 2500 RPM. Or check for stored codes in the ECU to see if any are present and related to the sensor.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club Last edited by 4Crawler; 08-22-2007 at 06:02 PM. |
#3 (permalink) |
Thanks for the feedback 4Crawler.I grabbed my flashlight and went outside to give this a shot.I ran the a/c idle valve in slowly and nothing changed.I then ran it all the way back out an no change either....Any other suggestions besides a garage.Thanks again for your help.
#4 (permalink) |
Check the idle up valve and it's associated Vacuum Switching Valve for clogs. It is not uncommon for the small vacuum lines and fittings to get clogged with crud from the intake. If that is OK, you can bypass the VSV by running the intake vacuum line directly to the idle up valve. If the idle speed increases, that points to an issue with the VSV. It make be internally clogged or it's coil may be burned out.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#5 (permalink) |
how about the same deal except 3vze?
__________________
'03 350z Turbocharged (totalled :( ) '04 Honda Accord LX V6 (first bone stock car I've owned in a while) 94 4runner SR5 4x4, 31x10.5's, SAS, Warn M8000 winch, Allpro bumper, Summit (K&N FIPK in different wrapping) CAI, flowmaster muff, 5.29's FOR SALE! '07 Harley-Davidson XL1200c, rush slip-ons |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Newbie w/ Questions... | BrentNClemson | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 06-06-2005 01:19 PM |
| Newbie has some questions | E30M3Pilot | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 06-01-2005 02:52 PM |
| Newbie questions | mbeck | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 08-04-2004 11:00 AM |
| newbie questions | willljzab | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-03-2004 01:43 PM |
| Newbie here! Have a few Questions? | TurboToys | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 11-25-2003 10:32 PM |
