Newb checking in under guise of brake question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-27-2009, 08:33 PM   #1 (permalink)
Hey, I picked up a '92 4runner for my wife today. I was happy with the deal- 2600 for a 144000 mi truck. It has an auto in it, which I am ok with considering it is primarily a DD for my wife and pending daughter. The PO said that the tranny was a fresh transplant out of a '95. It shifts smoother than any 2nd gen I've ever driven, so it might be true. Looks like fresh CV boots. Not much oil or fluid showing underneath. Fresh paint job, which actually looks pretty good. Everything seems to work, except a couple of switches on the driver's door cluster. Even that works fine sporadically. It just doesn't lock the passenger front door or work the left passenger window.
The brakes feel a bit squishy, but I'm thinkin' they just need to be bled. What are the symptoms for the brake booster going? (see, I knew I would find a question to ask).
Mostly, I'm just dropping in to say, "hi". I've learned a ton already. Next mission- find me a 1st gen to play with so I don't start cutting on my wife's ride
Mountain Cop is offline
Old 11-27-2009, 09:26 PM   #2 (permalink)
raydouble's Avatar
Quote:
FSM link for your rig here...
http://www.ncttora.com/fsm/1990-1995...5/contents.htm
Here are the checks + bleeding procedure....
http://www.ncttora.com/fsm/1990-1995...r/checkand.pdf
Usually a failing vacuum booster will have a high hard pedal due to lack of assist, hissing sound when brakes are pressed.
__________________
90' Pickup reg cab 22RE-W56-LCE dual chain conversion-tr*il gear slides-31' BFG MT-15x8 Allied rockcrawlers-SAW torsion bars-Rancho & Bilstein shocks-97' taco front
bumper-custom 6 leaf rear
01' 4Runner SR5 4WD 5VZFE all stock
raydouble is offline
Old 11-28-2009, 03:52 AM   #3 (permalink)
92 TOY's Avatar
Welcome to YOTATECH!!!!!!
__________________
1992 4x4 shortbed /22re/auto/192,000 miles--original owner(rebuild in process)
1988 SR5 4runner /V6/5 speed/248,000 miles/bought April 2009/***UNDER CONSTRUCTION***
2006 SR5 4runner (the wife's)....still being paid for...
>>>>***Check out My SLOOOOOOW Re-build Thread***<<<<
http://www.yotatech.com/f116/92-toy-...-start-188472/
92 TOY is offline
Old 12-30-2009, 07:18 AM   #4 (permalink)
Thanks! Got taken care of. I replaced the pads, bled the brakes and replaced a couple of leaking brake cylinders in back. Everything is nice and firm now. I appreciate the help and welcome.
MC
__________________
1992 4Runner 3.0. Auto 3.4 tranny swap, Flowmaster exhaust, ISR, Mrs Mountain Cop's daily driver, so the running boards stay on.
In process of acquiring a somewhat charred and melted 86 4runner from a family member whose barn burned. Build thread started. Build thread:
http://www.yotatech.com/f191/mountai...runner-200608/
Old 12-30-2009, 07:28 AM   #5 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Most shops like Meineke will do a free brake inspection for you but I see you got it figured out.
Welcome to Yotatech.
__________________
WabFab Off-Road, LLC
MySpace
Twitter
Facebook
7th Annual South East 4Runner Jamboree, 2010
The toughest part of a Jeep is the chick driving it.
waskillywabbit is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2009 InternetBrands, Inc.
