My speedometer doesnt work.HELP - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 01-16-2013, 07:06 PM   #1
yota1016's Avatar
I have a 1991 4runner and all of my gauges work accept my speedometer...the previous owner messed with the odometer and so idk if it messed it up, I haven't taken it apart yet but was curious about any ideas? Please and thanks
yota1016 is offline   Reply With Quote
Old 01-16-2013, 07:21 PM   #2
StewsRunner's Avatar
Does your odometer work? Pull your tach out and drive around the block and look at the needle in the speedo cable. If it spins, the tach or VSS which is in the tach, is bad. If the needle does not spin, your cable snapped, simply replace.
StewsRunner is offline   Reply With Quote
Old 01-16-2013, 07:45 PM   #3
yota1016's Avatar
My tach does work.
And could it also be as simple as an electrical problem? Or is it most likely that cable?
Old 01-16-2013, 07:49 PM   #4
Well IIRC the vehicle speed sensor is actually in the tachometer and I do not think you can replace it, you need to replace the entire unit. I'm sure it's one of the few. Very simple check.
Old 01-16-2013, 07:50 PM   #5
yota1016's Avatar
Ok thank u.
How do I remove the speed sensor from the transfer case? Phantez 86-95 Trucks & 4Runners 3 09-30-2015 09:24 AM
Advice on a possibly bad 2TR-FE and shady dealer. charlie_fong General Vehicle Related Topics (Non Year Related) 0 09-27-2015 11:06 PM
Speed sensor broken off in transfer case. Rickstwowheels 86-95 Trucks & 4Runners 1 09-21-2015 06:21 AM
P0500 and a flame thrower... matt1833 95.5-2004 Tacomas & 96-2002 4Runners 0 09-16-2015 08:11 AM
91 Toyota speedometer problem toyotafreak98 86-95 Trucks & 4Runners 9 09-10-2015 03:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
