my '94 4runner running rough - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 12-05-2008, 12:20 AM   #1
hello all you toyota techs out there!!!!!!! Got myself a brain buster here. My 3.slow at 90K al of the sudden got a little shake at idle,not much noticable at cold start but as the rpms drop, it shakes moderately in idle but when i start to open the throtle it starts to shake more to a mifire condition and at 2000 rpms it all smooth. Checked all the standard things all seem to check ok. Have a fuel air guage and during that idle to 2k rpms guage reads lean, no codes on ecm. tomorow will chek pcv hose and valve and will do a compressin test. Plugs tips look white which definetly steers me to a lean condtion. But why? Vacuum leak!!! where, cant see one or maye some one knows of common areas to look ?. Help !!!!!!
Zinek is offline   Reply With Quote
Old 12-06-2008, 05:29 PM   #2
abecedarian's Avatar
a vacuum leak could cause what you experience. also, the coolant temp sensor can, as well as a faulty/maladjusted throttle position sensor.
abecedarian is offline   Reply With Quote
Old 12-28-2008, 08:30 AM   #3
Ok, did a compression test and am getting 160 dead even on every cylinder, what i did was use a fuel injection cleaner, added to a 3/4 tank of gas and ran it till tank was empty, major improvement, almost perfect. I also forgot to mention another condition that is happening during cold starts thats been going on for a while now. When i start it in the morning and start driving, I watch the temp guage. When it gets to about a 1/4 the truck kind of stumbles when i give it gas, then i give it more gas and the truck picks up fine and then it seems to run ok.
94 runs without fuel pump on? puffin04 86-95 Trucks & 4Runners 3 07-10-2015 10:17 PM
22re rough idle and stumbling Yont283 84-85 Trucks & 4Runners 6 07-07-2015 06:59 PM
1999 4Runner 4WD t-case issue TNRunner88 95.5-2004 Tacomas & 96-2002 4Runners 0 07-01-2015 09:00 PM
Idle issues Alex Bessinger 86-95 Trucks & 4Runners 4 06-28-2015 11:05 AM
1988 Toyota Pickup V6 rough idle and runs rich [email protected] Newbie Tech Section 1 06-26-2015 09:15 AM
Tags
1998, 30, 4runner, 91, 96, codes, common, forerunner, idle, idles, leaks, rough, ruff, running, shakes, startup, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
