motor swap question: 2wd 3.4 into a 4wd?
Old 03-06-2012, 04:14 AM
danieljohnson57's Avatar
i have a 98 tacoma 4x4 limited extended cab with the 3.4 and its an automatic. i bought it and the motor is no good. i have a friend that owns a towing company/junk yard and he has a 2002 tacoma pre runner in the yard that was flipped over which is also a 3.4 and automatic. my question is will the motor out of the 2wd pre runner work in my 4wd? if not what will i have to change over and is it worth my time or do i just need to go hunt a motor out of a 4wd?thanks
Old 03-06-2012, 04:22 AM
Fossilized
Staff
dropzone's Avatar
Welcome to yotatech.
Lots of good info here in the stickies:
https://www.yotatech.com/forums/f160/
I would think it would work fine swapping over things like the oil pan, but you should find your answers with the link above
wii_tarded's Avatar
I can't think of any reason why it would not work, the 4WD system is separate from the engine....but I could be totally wrong.
Old 03-06-2012, 10:21 AM
totally a bro
Staff
vital22re's Avatar
Strip the donor motor to just a long block with lower manifold. Swap over your harness and throttle body. Possibly the oil pan/ pickup for oil pump.
Old 03-21-2012, 12:03 PM
snide4's Avatar
Will it hurt to leave the rubber outta my motor mounts im tryin to put a 305 in my 86motor toyota 4runner
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
mskalmus
05-28-2017 07:51 AM
Cplmike
07-08-2015 08:47 PM
karbin
07-05-2015 11:37 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: motor swap question: 2wd 3.4 into a 4wd?
