Master Cylinder problem?
i drive a 1984 toyota pickup. its a dlx so its extended cab and such. my problem is my brakes. i just did a 4 wheel brake job and i still have a low pedal and only my front brakes work. It also leaks brake fluid, i have to fill it every couple of hours. its getting annoying so im wondering if its my master cylinder thats broke?
(4) wheel brake job consisting of doing what?
Leaks brake fluid where? Out the tailpipe?
What was your bleeding procedure?
bled all four brakes, did not bleed load proportioning valve, and i believe its leaking out of the back passenger side wheel cylinder because it was bad, but it leaks under load or not...if i fill it and park it, it will be empty by morning...i should have it fixed soon because i went to NAPA yesterday and ordered wheel cylinder and master cylinder, if that dont work then im jumping that P.O.S
jasonty
41
12-23-2018 01:00 PM
