Links to FAQ's and Info! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-10-2006, 09:13 PM   #1 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
Updated 3/13/09
Well I got tired of looking through several threads to find the thread I wanted, so I started a list of links to FAQ's and info about various things... Since its all nicely compiled I figured I'd share it. Hope this helps some of ya!
I'll keep adding to it, if I find more, and if theres some things that some of you know about, post them and I'll add them in!
General 4Runner/Pickup FAQ's:
.......... http://www.pirate4x4.com/forum/showthread.php?t=459180
.......... http://www.yotatech.com/~corey/tech/techpage.htm
.......... http://www.yotatech.com/~corey/4runner_faq.htm
.......... http://www.yotatech.com/showthread.php?t=66255
General FZJ80 FAQ's:
.......... http://www.sleeoffroad.com/technical/technical.htm
Online FSMs
.......... http://www.ncttora.com/fsm/
.......... http://www.4x4wire.com/forums/showfl...&Number=752426
AXLES:
Comparisons: http://www.pirate4x4.com/tech/bible/index.html
.......... http://home.4x4wire.com/erik/diffs
TOYOTA 8": http://www.4crawler.com/4x4/CheapTri...ch/index.shtml
.......... Rebuilding Info: http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4x4wire.com/toyota/mainte..._end/teardown/
.......... .......... http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
.......... .......... http://www.4x4wire.com/toyota/tech/gear_setup/
.......... .......... http://www.pirate4x4.com/forum/showthread.php?t=281879
Toyota Component Strengths (D44/D60 too): http://www.pirate4x4.com/forum/showthread.php?t=350905
D44's: http://www.4x4wire.com/forums/showfl...b=5&o=&fpart=1.
D60's: http://www.pirate4x4.com/tech/billav...ont/index.html
D70's: http://www.pirate4x4.com/tech/billavista/D70/D70.htm
14 bolt: http://www.pirate4x4.com/tech/billav...ble/index.html
Hybrids: http://www.pirate4x4.com/tech/billav...HybridAxle.htm
Rockwells: http://www.pirate4x4.com/forum/showthread.php?t=313836
.......... http://www.jpmagazine.com/techarticl...ton/index.html
.......... http://www.fourwheeler.com/techarticles/77419/
Lockers:
.......... Toyota 8" Air: http://www.4x4wire.com/toyota/tech/arb_locker/
.......... Toyota IFS Air: http://www.4x4wire.com/toyota/4Runne...ifs_airlocker/
Stock Toyota Engine Improvements and Info:
20R/22R: http://ttora.com/forum/showthread.php?t=84715
22R to 22RE Conversion: http://pirate4x4.com/forum/showthread.php?t=316661
22RE: http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
22RE Superchargers: http://www.toyotacatalog.net/M1WebGe...F-E6DF0C03E232
Engine Swaps into Pickup/4Runners:
General: http://www.mindspring.com/~jayk3/toyota/swaps.htm
.......... http://www.pirate4x4.com/forum/showt...hreadid=175795
Buick 231: http://www.off-road.com/toyota/buick_v6_swap.html
Chevy 4.3: http://www.off-road.com/toyota/tech/other/v6swap.html
Chevy 350:
Ford 302/351: http://www.yotatech.com/showthread.php?t=72065
.......... http://www.whiteknucklemotorsports.n...d=38&Itemid=27
Toyota 3.4 V6: http://www.yotatech.com/showthread.php?t=82145
.......... http://www.yotatech.com/showthread.php?t=81553
.......... http://board.marlincrawler.com/index...&topic=19684.0
.......... http://www.andrewzook.com/content/view/22/37/
Toyota 22R to 22RE: http://www.yotatech.com/f115/22r-22re-swap-129693/
Toyota 5M/7M: http://www.4x4wire.com/toyota/tech/supra/
.......... http://4x4.4t.com/4runner/7mswap.htm
.......... http://www.off-road.com/toyota/tech/supraswap/
.......... http://www.supracharged.com/forum/viewtopic.php?t=298
Toyota V8: http://www.yotatech.com/showthread.php?t=54771
Toyota Diesel (1KZ-TE): http://www.yotatech.com/showthread.php?t=77103
Engine Swaps into FZJ80s
Transfer Cases:
Double Toy Cases: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.marlincrawler.com/docs/dualcase/install.html
Double NP Cases: http://medusa.ih8mud.com/NP205/Doubler.html
.......... http://www.offroaddesign.com/catalog/doubler.htm
Toy Cases Info: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.off-roadweb.com/tech/0607...des/index.html
NP Cases Info: http://www.off-road.com/chevy/tech/transfercaseguide/
4Runner/Pickup Suspensions and Lifts:
SASing: http://www.yotatech.com/showthread.php?t=73430
.......... http://www.yotatech.com/showthread.php?t=73882
.......... http://www.tacomaterritory.com/forum...isplay.php?f=7
.......... http://www.toyotaoffroad.com/Article...kleman_SAS.htm
Toyota Rear Springs up Front: http://www.pirate4x4.com/forum/showthread.php?t=265669
Chevy 63" Rear Swap: http://www.yotatech.com/showthread.php?t=71759
.......... http://www.pirate4x4.com/tech/chevyswap/index.html
.......... http://www.pirate4x4.com/forum/showt...threadid=20665
4Links: http://4wheeloffroad.com/techarticle...131_0306_link/
.......... http://www.4wheeloffroad.com/techart...ension_part_2/
Coil Conversions: http://www.yotatech.com/showthread.php?t=105460
.......... http://www.offroadsolutions.com/susp...#7995_coilover
Body Lift + Flat belly: http://www.4x4wire.com/toyota/tech/drivetrain_lift/
.......... http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
FZJ80 Suspensions and Lifts:
4Runner/Pickup Steering:
.......... Rebuiding Stock: http://web.archive.org/web/200503220.../taco/box.html
FZJ80 Steering:
Winches/Winching: http://www.pirate4x4.com/tech/billav...ery/index.html
4Runner/Pickup Rear Bumper Design
.......... Mulit-mount: http://www.yotatech.com/showthread.php?t=87892
Vendors: (NOTE: I have no connection to any of these, they are provided merely for reference)
ARMOR - Front Bumpers:
..... 4Runner/Pickup:
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
ARMOR - Sliders
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...iders_main.htm
..... .......... 4xInnovations: http://www.4xinnovations.com/pages/guarding/sliders.htm
..... .......... Hanna Quality: http://www.hannaquality.com/products.html
..... .......... Man-A-Fre: http://www.man-a-fre.com/feature_ite...ocksliders.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/sliders.shtml
ARMOR - Rear Bumpers:
..... FZJ80: 4x4Labs: http://www.4x4labs.com/bumpers.shtml
..... .......... Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/rearbumpers.shtml
AXLES/GEARS/DIFF PARTS:
..... FZJ80:
LIFT KITS - Body:
..... FZJ80:
LIFT KITS - Suspension:
..... FZJ80:
GENERAL MODEL SPECIFIC GOODIES:
..... FZJ80:
OTHER PARTS:
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 10-17-2006, 06:27 PM   #2 (permalink)
colsoncj's Avatar
Online FSMs
__________________
Cory
colsoncj is offline
Old 09-11-2007, 11:50 AM   #3 (permalink)
Gator's Avatar
Thanks
I just posted a thread regarding a swap from the 3vze to a Chev 4.3 and happened to see this link at the bottom of the page.
Looks like you have some useful links here, thanks.
__________________
Current Setup: 94 X-Cab 4x4 w/ 3.0, Auto, 1.5" BJS & Shackles, 33x12.5-15 BFG MT's, Detroit locker w/ 4.88 gears, ISR and Air Box mods, All-Pro winch bumper, Trail Gear Rear bumper, Warn XD9000i, custom body work by trees and rocks.
Future Mods: 1UZFE Conversion, A340H to R150F conversion, SAS, dual cases, 12v Air Compressor & tank.
Gator is offline
Old 09-11-2007, 03:30 PM   #4 (permalink)
colsoncj's Avatar
no problem... i tend to update it every now and again when i find new stuff... if anyone finds any bad links, let me know, or if they find any links to add, or information to add, please PM me and i'll get it added right away!
__________________
Cory
colsoncj is offline
Old 07-13-2008, 07:17 PM   #5 (permalink)
colsoncj's Avatar
updated and fixed.
__________________
Cory
colsoncj is offline
Old 03-12-2009, 11:11 PM   #6 (permalink)
colsoncj's Avatar
updated again
__________________
Cory
colsoncj is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Links to FAQ's and Info! colsoncj Ozarks 5 03-12-2009 11:11 PM
FAQ's on IFS camdsgn Introductions & New Arrivals 5 06-04-2007 11:36 AM
Links to V8 conversion info... nineball 86-95 Trucks & 4Runners 3 10-13-2006 04:08 AM
Post pics of '78-down trucks here and links for info LowHiLux Pre 84 Trucks 5 10-08-2006 06:56 PM
info and part links??? roninb18 95.5-2004 Tacomas & 96-2002 4Runners 1 09-10-2003 01:55 PM
2009 InternetBrands, Inc.
