| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Which lift and how much?
#2 (permalink) |
You can clear 33x10.5 tires in most situations without even lifting the truck..
__________________
1990 Toyota 4Runner - SR5, 22RE, 5 speed, 35" Mud King XT, a bunch of mods. 1986 Mazda B2000 - 5 speed, carb'd 2.0, the winter beater. 1979 Datsun 280zx - 2 seater, 5 speed, stripped interior, etc. 1998 Nissan Altima - 5 speed, 1981 280zx turbo snowflake rims. 1985 Toyota Pickup - SR5, 22RE, 5 speed, Xtra cab, lifted 2", 35" boggers, etc - Sold 1983 Datsun 280zx - Turbo Intercooled L28ET - Crushed. 1985 Nissan 300zx - 5 speed, race prepped, etc - Crushed. IFS Club #7 |
#3 (permalink) |
Yeah I know but the front springs are sagging pretty bad and need to be replaced, rather than buy some stockers and new shocks, because they need to be replaced, I figured it would be wiser to replace with lift now and be happy.
#4 (permalink) |
you sould go with a high steer setup for sure so it will be out of the way. also if you dont care about flex than you can go with the cheaper lifts(Rough Country or Tough Country) but they will have a rough ride. in most lift kits you get what you pay for. you might call marlins and ask about there lifts.
__________________
'82 toyota pickup 5" lift, weber 36deg carb, 32x11.5 sx super swompers,rear aussie locker,5.29 gears, cb, and 261*c cam |
#5 (permalink) |
OME. Springs, shackles, greasable pins, and shocks. It'll cost you about $1200 which I'm sure is more than twice the price of the cheap kits but it's a very good setup. It's advertised as 2 1/2" but you'll get at least 3" out of it.
I think 3" isn't quite enough to go with high steer. I installed a Marlin tie-rod with FJ80 tie-rod ends and stayed with the OEM steering configuration. The tie-rod is above the centerline of the front axle so I personally don't think the high-steer does much for you wrt clearance. Most go to it to help eliminate bump-steer but unless you're a hard core rock climber that probably isn't a big issue.
__________________
1985 4Runner 1997 FZJ 80 2007 HDJ100 - DD |
