Leaking rear differential
#62
Good write-up on pulling the 3rd:
- https://www.yotatech.com/forums/f116...p-pics-179241/
If you have ABS, the rear axle sensor is on top of the 3rd:
#64
Hey, not 100% on-topic, but was mentioned above - where are you guys getting the 10mmx1 caps for your brake lines?? NAPA doesn't carry 'em, at least not up here. I could really use some! Seems like every job I have to do requires removing lines, and I am getting SICK of draining the MC...
Thanks!
Good luck with the Diff. seal - doesn't seem to bad a job for ya.
Thanks!
#67
4:10 vs. 4:56 vs. 4:88 on 31x10.50 tires need help...
Not sure what to go with would like to hear from owner's and there experience what works best there dislikes and like. Thanks Guys!
#69
I've got a 22re automatic on 31s and the 4.30 stock gears suck. It's driveable, but it struggles up hills and in headwinds, and if you can afford to regear I heartily recommend it.
jerusry
10-19-2015 05:28 PM
Iceman4193
07-15-2015 04:48 PM
Avenged
07-09-2015 07:55 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
07-08-2015 07:15 PM
