Idle Issue - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-02-2008, 04:17 PM   #1 (permalink)
Idle Issue
Between shifts the motor revs to around 3k rpms then drops down to 1500rpm where it idles right now. I just purchased it(87 4runner 22re) I have only replaced the plugs so far. I am going to replace the o2 and remove cat. next, is there anything else that could cause this issue? Thanks in advance from a forum newbie.
Doug
DeadGame420 is offline
Old 01-11-2008, 07:09 PM   #2 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
I'm assuming a manual? There is a little dashpot that is supposed to hold the throttle right off idle when decelerating or letting off the throttle, could be sticking I assume, but i've never seen it rev the motor up that far. Its located below the the throttle body (kinda sorta). check it and the throttle linkage, might have some binding.
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Build in progress: http://ttora.com/forum/showthread.php?t=129727
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Old 01-12-2008, 12:08 AM   #3 (permalink)
stormin94's Avatar
Mine used to do that, but it doesn't anymore, so I guess it fixed itself
__________________
1994 Toyota 4Runner SR5 4X4
213,000 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighter 100 Watt lights
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is offline
Old 01-17-2008, 10:48 PM   #4 (permalink)
stormin94's Avatar
I spoke too soon, I guess. After about 18 months of not idling high, it started doing it again the other night while I was driving home. Idle was around 2,000RPM, and then after a while, it was about 1700RPM
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 01-18-2008, 07:08 AM   #5 (permalink)
colsoncj's Avatar
stormin, check your idle adjustment screw, it might be backing out on ya...
__________________
Cory
colsoncj is offline
Old 01-18-2008, 07:09 AM   #6 (permalink)
colsoncj's Avatar
wait, yours is a V6... do you know if it has an idle adjustment screw on the throttle body?
__________________
Cory
colsoncj is offline
Old 01-18-2008, 07:56 AM   #7 (permalink)
Ringmaster's Avatar
Quote:
A "Self healing Toyota"?
That would be nice.
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender.
Ringmaster is offline
Old 01-26-2008, 11:56 PM   #8 (permalink)
stormin94's Avatar
I don't quite know where the idle adjustment screw is. I'll look tommorow when I get your pics.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 01-27-2008, 12:15 AM   #9 (permalink)
Kiroshu's Avatar
2nd Gen 4runners always have idle issues. Its just what they come with when you buy one. It stops for a while then comes back. Tune it up it stops then comes back. Its hard to totally eliminate the messed up idle issues or rumbling and missing. Toyotas are old yet wise machines. They get cranky everyonce in a while but calm.But yea adjust your timing and you'll be good for a while until it shakes back into place.
_______________________________________________
95 Toyota 4runner SR5 V6 3.0 Automatic 149,600 Miles (bone stock)
Kiroshu is offline
Old 02-05-2008, 10:03 AM   #10 (permalink)
Matt16's Avatar
Try adjusting the idle. It was the miracle cure for all my idle woes.
__________________
1990 Toyota 4Runner 22RE 5spd
*Aussie Locker*York OBA*
Quote:
Originally Posted by DaveInDenver View Post
Yeah, I do think it's sort of funny. Can't you see a roomful of Toyota engineers looking at a relay rod, scratching their heads and saying 'Hmmm, this part wore out after 200,000 miles and 16 years, this is just unacceptable.'
Quote:
Originally Posted by DeathCougar View Post
next time when the front of your engine sounds like a can of spoons, fix it
Toyota FAQ link
More info on 4Runners
Matt16 is offline
Old 02-07-2008, 09:38 PM   #11 (permalink)
jtlinna3vze's Avatar
Quote:
which way did u adjust? up or down?
__________________
1994 4Runner SE-R IFS 5 on the floor - KYB shocks - MOOG chassis and steering - YMJ intake - YMJ taillights / corner markers - bed liner floor - 1st gen midland 102" - 31 10.5 15 kelly AWR - cup holder
jtlinna3vze is offline
Old 03-04-2008, 12:44 PM   #12 (permalink)
lotalucas's Avatar
you could need to adjust you'r idle but it's more likely, at least through my experience that it's either a leak somewhere in your intake or it's your timeing chane. Get some soapy water in a spray bottle and spray it around your intake. If you see bubbles blowing around a spot you know it's a hole. You can also spray carb cleaner around and if you find a spot that you spray it and the rpms go up you know you know you have a vaccuum leak. it also could mean you'r timing just off. you can check it yourself if you have a timing light or if you want a mechanic to do it it's usually like 50 bucks or so. It could also be your timing chain which would suck and the only way you could check it is to take off all the covers and the fan and look at it and if you do that you might as well replace it anyways.
lotalucas is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
04 2.7l idle knock issue Mean04Tacoma 95.5-2004 Tacomas & 96-2002 4Runners 6 10-28-2007 09:51 PM
Idle Issue JEBSR5 86-95 Trucks & 4Runners 25 03-16-2007 06:05 PM
Idle issue Sonofmayhem 86-95 Trucks & 4Runners 40 02-05-2007 06:50 PM
idle issue jayson161 95.5-2004 Tacomas & 96-2002 4Runners 5 12-13-2004 08:57 PM
Idle spped issue markjs 95.5-2004 Tacomas & 96-2002 4Runners 8 01-03-2004 02:32 AM
2009 InternetBrands, Inc.
