how many splines- rear axle - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-03-2010, 07:18 AM   #1
i have a 88 pickup 5 speed 4x4 22re. i'm putting a spool in the rear. this is only a mud truck (never sees the road). having a problem finding out how many splines are on the rear axles 27 or 30. the axle code is G292. any help would be helpful. thanks
jason22 is offline   Reply With Quote
Old 07-03-2010, 07:22 AM   #2
xxxtreme22r's Avatar
take the axle out and count them ????? Gotta take it out anyway right.
xxxtreme22r is offline   Reply With Quote
Old 07-03-2010, 07:24 AM   #3
All pre-'95 4-cylinder 4wd mini-trucks & 4Runners use the Toyota 8" 2-pinion differential rear (except turbo models). This is known as the "4cyl diff." This diff is by far the most common diff in older Toyotas. These are 27 spline axles.
'86-95 4cyl Turbo and V6* trucks and 4runners, and ALL '96+ 4Runners use the Toyota 8" 4-pinion differential in the rear. This diff is known as the "V6/Turbo diff." These are 30 splines.
Old 07-03-2010, 07:34 AM   #4
thank you sir
Old 07-03-2010, 12:32 PM   #5
rattlewagon's Avatar
I was under the impression that all rears were 30 spline. and the fronts were 27 spline. But i could be wrong
this is a 4cly spool that is 30 spline.
http://durasolid.com/differential-pa...0ulw-31-4.aspx
rattlewagon is offline   Reply With Quote
Old 07-04-2010, 04:51 AM   #6
ok after looking at this, I have conflicting answers both on 4x4 wire:
http://www.4x4wire.com/toyota/faq/parts/
http://home.4x4wire.com/erik/diffs/
Old 07-07-2010, 06:50 AM   #7
Huh. Does some one know the answer to this.
Old 07-07-2010, 07:05 AM   #8
waskillywabbit's Avatar
Pretty sure all rear axle shafts are 30 spline. I got several sets sitting out. I'll count tonight.
waskillywabbit is offline   Reply With Quote
Old 07-07-2010, 07:25 AM   #9
scuba's Avatar
I don't see anything conflicting in those.
The spline count on the first link is referring to axles.
The second link says 27 spline pinion and does not say anything about spines for the axles. Though, directly under it, it states the V6 diffs have 30 spline axles and 27 spline pinion.
The yukon spool states "Yukon Performance 1-11/16" deck steel spool for Toyota 8.0" truck with 30 spline axles" and the description is "Toyota 8" 4 Cylinder, Full Spool, 30 Spline"
The gear code or G292 confirmed, 8", 4.10, 2 pinion open.
Here's your spool.
http://www.alljeep.com/oscommerce/pr...ucts_id=174577
You've got 30 spline axles, dude.
scuba is offline   Reply With Quote
Old 09-11-2010, 07:19 PM   #10
drew303's Avatar
all toy diffs take 30 spline axle shafts.
only front toy shafts neck DOWN to 27 spline for the birfield but the other end of the shaft isnt necked down and is 30 spline to slip into the toy third
drew303 is offline   Reply With Quote
Old 09-11-2010, 07:39 PM   #11
SoCal's Avatar
subscribed
SoCal is offline   Reply With Quote
Old 09-11-2010, 08:30 PM   #12
MudHippy's Avatar
Quote:
That's a fact jack!(pardon the pun)
Quote:
Uh-huh, like he says. (not that it really matters...but my 88 has the V6, axle code G292, and has a 4-pinion 8" with 4.10 gears...axle codes can be wrong...mine should be G294)
Not quite right. Close though!
Front & Rear Solid axle = 30 spline axleshafts for all 8" rear differentials. Front 8" axleshafts are 30 spline inner(differential end), 27 spline outer(birfield end), 30 spline stud(hub end)
Front IFS axle = 27 spline stubshafts/side gear shafts for all IFS 7.5" differentials
IFS CV halfshaft = 27 spline inner shaft(at the inner tripod and outer birfield-type joints), 26 spline stud(hub end)
Just went out to the shed to count the splines on my spares, got both kinds 7.5" IFS & 8" rears. Triple-checked and CONFIRMED!
MudHippy is offline   Reply With Quote
Old 09-12-2010, 04:36 AM   #13
thanks MudHippy for clearing that up. I am usually good with finding info, but sometimes I read it wrong.
Old 11-05-2010, 12:58 AM   #14
drew303's Avatar
Nice clarification Mudhippy. IFS has been erased from my memory; did a hardwipe reset to 000's to try and rid my brain of IFS intel... it was corrupt and took up to much valuable brain storage space had to go after SAS hehe
:-p
FS[PacSouthWest]: 2- 8"3rd members:4.88 ratchet lockers,new setup kit, rear axle rebuild kit,diff armor jerusry Axles - Suspensions - Tires - Wheels 1 10-19-2015 06:28 PM
FS[GreatLakes]: Toyota collection part out 88sasturbotoy Axles - Suspensions - Tires - Wheels 2 08-11-2015 02:56 AM
4.88 question deepmarsh 84-85 Trucks & 4Runners 5 08-06-2015 04:44 AM
Bent frame reliablity yourrealdad 95.5-2004 Tacomas & 96-2002 4Runners 2 07-21-2015 12:13 PM
1984 extra cab build up toyoda8488 84-85 Trucks & 4Runners (Build-Up Section) 2 07-05-2015 11:18 PM
Tags
18, 57, 64, 8, adding, axel, axle, bmw, count, determining, end, rear, spline, splines, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
