Sign in using an external account
| Newbie Tech Section Often asked technical questions can be asked here |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
How long should a battery last
__________________
2000 4Runner SR5 |
#2 (permalink) |
Personal
Sales Rating: (0)
That is a long time, but I've had one that was in my 4runner in '01 or '02. I got an optima, and put that battery on the shelf for a while, then when the batt. in the GMC went out we put the one from the runner in it. It's been in there ever since. 5 or 6 years at least and not a problem. It's probably kick the bucket soon though...
__________________
<===This picture is me and my 4runner when I was about 4 years old. 87 4runner 4x4 SR5 22RE ARB Bull Bar, 31X10.50 Mastercraft M/T's, Stock 4.10 Gears, Flowmaster Muffler, LCE Header AISIN Manual Hubs, Marlin Crawler Sliders Dead motor 3.4 swap or something else to come |
#3 (permalink) |
Personal
Sales Rating: (0)
I just put a new one in my 2000. It still wasn't completely gone yet but I put a meter on it and it was only showing 11volts in the cab with it off. It was sounding a little week on startup also. I went with the Costco battery. It doesn't matter were you go lately the price of lead has gone up, thus driving up the cost of batteries. What used to be a $40 -$50 dollar battery is now $70 bucks. Optimas were around $110 now $149.
__________________
Pioneer HU, Audiobahn 10.100watt Sub, Sirius, JBL comp speakers in all four doors, Cobra NWWXST CB W, Quadwrap, Wolo Air horn, K&N FIPK,Tokico Trekmasters,Tundra TRDs, Revtec spacers w/extended studs,Energy bushings on steering rack /front swaybar,SS front diff. drop kit w/skid plate mod,OME 890 Rears with OEM LC Tokicos,Ebrake ext. bracket, BFG AT/KO's, ProComp 1078 Alloys, Magnaflow SS muffler, Hayden 1678 Tranny Cooler, 85watt Amber fogs, 7 Way R/V jack for the boat. |
#4 (permalink) |
Personal
Sales Rating: (0)
the one in my 1st gen is at least 10 years old and hasnt given any problems yet
__________________
1989 Toyota 4runner Special Edition - Rebuilt 22re bored .20 over, 5 speed swap, 4.30 gears, - Magnaflow Performance Exhaust with Magnaflow Hi Flow Catalytic Converter, Monroe Sensa-Tracs Shocks all around, 4runner AALs, Checkerplate front skid, Softopper , Clear Corners and Turn Signals, Eagle Alloy Rims with 31x10.5x15 M/T tires, 2 12" JBL Subwoofers / MTX AMP, Pioneer Premiere Speakers, JVC KD-G730 MP3/CD/Bluetooth |
#5 (permalink) |
Personal
Sales Rating: (0)
your lucky to get away with 3-4 years with an ultima out here in teh desert because it gets so frikin hot in the summer the plates in the battery expand and contract and move around untill the plates touch then its no good. i reccomend an ultima ( good warranty )
__________________
318,000 miles thats all i gotsta say 90' 2 door 3.0 32 11.5 15 <- no lift no rub it even fixes itself!!! ( it also breaks itself ) |
#6 (permalink) |
Personal
Sales Rating: (0)
The original in my 99 made it for 8 years before biting the bullet.
Both the heat of summer, and the cold of winter is when a bad battery will usually take a dive.
__________________
99 4Runner, 3.4, 5 spd., Manually shifted E-Locker, 4:30 gears, 285/75/16 MTR's, Airbox mod through the bottom of the inner fender. |
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
I should add that I am in the northeast so I don't have the heat of the desert but do have the cold of the winters. It has is parked in the garage for the last 5+ years.
__________________
2000 4Runner SR5 |
#8 (permalink) |
Personal
Sales Rating: (0)
normal battery life is about 5 years. If you plan on going on any long trips i would just go ahead and replace the battery. I would just make sure to get a warrantied battery like die hard or interstate.
__________________
1984 toyota sr5 4x4 22r w/ weber 32/36 Pro comp 4" front springs & 3" rear downey spring Home made On-board air system V6 4.88 lock rites F & R Bilstein 7100 reservoir shocks |
#9 (permalink) |
Personal
Sales Rating: (0)
Avg life of a battery is 3-5 years give or take a few here or there. I seen bad ones a year old, 3 months old, 10 years old, etc. I work as an AAA certified battery service tech.
A few things happen to batteries: They develop a bad cell: - Shorted cell due to failure of the separator between the positive and negative plates - Broken internal connections due to corrosion - Broken plates due to vibration and corrosion Also - Low electrolyte - Cracked or broken case - Broken terminals - Sulfation after prolonged disuse. But what basically kills a starting battery is alot of discharge and recharge cycles. If your an idiot and dont drive your car alot or leave the lights on like 20x a month the battery wont last.. Do not ever go by those dumb eyes on the battery that mimic a hydrometer, they only measure one cell..not multiple cells. A hydrometer will measure the cells, all should be within the proper scale. Generally speaking, if you dont do anything to discharge and recharge the battery alot and it doesnt get a bad cell expect about 5 years..
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#10 (permalink) |
Personal
Sales Rating: (0)
My old Cobra's battery was 8 years old before I sold it. OEM Motorcraft. Unbelievable life.
__________________
'97 4Runner Limited 4x4 w/Locker Grey (Red & Blue) Wire Mod 2Lo Mod Tundra DC Non-TRD front with stock Tundra Tokicos (2.5") Downey 3" rear lift with Monroe Reflex Shocks (Thanks Chaplain!) Soldier for Christ. |
#11 (permalink) |
Personal
Sales Rating: (0)
I have my optima for 10years if you want to keep it fine or you can change it
__________________
88 4.3v6 4runner duals fullwidths and 37mtrs and a happy owner |
#12 (permalink) |
Personal
Sales Rating: (0)
I've had my Optima deep-cycle yellow top, for just over ten years now. It still works great.
#13 (permalink) |
Personal
Sales Rating: (0)
what about the 2005 Runner Batteries. I can't find any documentaiton on these. Typically they are 7 year batteries but I am wondering if they have Super Long Life Batteries - like 10 years??
__________________
Andrew from Connecticut 2005 4Runner SR5 V8, 5-Speed Auto, All Wheel Drive, 17" Rims, Black/Grey After Market: *K40 Radar/Laser Detector/Diffuser Front (Twin Sensors) & Rear (built in). *Python GPS Stolen Device Tracker. *Parrot Hands-Free Cell Kit. *Back Up Sensors. *Tinted Windows. *Security Box inside center console and bolted to frame. *Nokian WR Tires (265/70/17) *Bilstein HD Shocks (Front & Rear) *TRD Front Brake Pads 2005 4Runner SR5 V8 AWD |
#14 (permalink) |
Personal
Sales Rating: (0)
I have a 1988 pickup that I have owned for 19 years. I would say 4 years for a lead acid battery and you got your moneys worth. Longer than that you are lucky and living on borrowed time.
In my opinion the warranty thing is a gimmick. Has nothing to do with the quality of the battery. Same battery can be sold under different brand names, but the warranty is longer on the battery that usually costs more. Go to Lowes or Home Depot and price a water heater with a 5 year warranty vs. 7 years. Same exact same water heater. You pay more for the one with the 7 year warranty, because consumers will pay more. The company that makes stuff like this is smarter than the average consumer. |
#15 (permalink) |
Personal
Sales Rating: (0)
when this one does die i would recomend an optima andif you have a system and lights and stuff id get the yellow top i can run my system with an 1100 watt amp for 10 hours at work and i have never had a problem starting after that plus it has a great warranty
__________________
. . . DIRTY DIESEL She aint purrin, She's damn sure growlin . . . . |
#16 (permalink) |
Personal
Sales Rating: (0)
auto batteries last about THREE good summers in phx.
__________________
2000 4Runner 3.4 SR5 4x4 5-Speed 105K, Revo's 694 tires w/2006 trd rims 2001 tacoma 3.4 prerunner trd, auto, x-cab, 95K 4runner items replaced : both rear axle seals Denso starter @ 82k TPS Sensor @ 78k Denso alternator @ 103k Spare tire carrier @ 104k Tacoma items replaced starter @ 11k oil pan gasket @ 10k TPS Sensor @ 90K SOLD 2003 Toyota tacoma prerunner std cab, short bed*traded to dealer* 2003 Toyota tacoma trd, 5-speed, x-cab, 4x4*major wreck, traded to dealer* |
#17 (permalink) |
Personal
Sales Rating: (0)
I have no idea how old my battery is but after camping and a night out in -3F, it started right up with no problem. I am thinking that it is at least 10.
__________________
92 4Runner SR5 V6 4X4 Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares. 2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear. - Sold 2004 Honda CRV EX stock belongs to wife. 2010 Corolla S, no mods yet. |
#18 (permalink) |
Personal
Sales Rating: (0)
just replaced my autocraft silver battery with Optima 34R after 4.5 years
__________________
1996 Limited - OME 881/906 w/comfort shox | Deckplate | Hayden 1678 | 265/75R16 Revos | Koyo A1998 bypassed | Husky liners | Optima R34 Red Top | '99 Cupholders | Rear diff breather mod 2012 Limited - |
| Tags |
| 1998, 2007, 4runner, batter, battery, builtin, catalytic, converter, crv, eye, hydrometer, long, runner, t100, tacoma, toyota, year |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| How long did your toyota battery last?? | Mahoney | General Vehicle Related Topics (Non Year Related) | 1 | 10-30-2007 06:39 PM |
| Road trippin long way around to Ft Collins,, really long way | neliconcept | Off Road Trip Planning, Expeditions, Trips, & Events | 3 | 06-22-2007 05:57 PM |
| How long after dc battery OBDII Ready | Vermonster | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 10-11-2006 11:44 AM |
| How long your original battery last? | 4RUNR | 95.5-2004 Tacomas & 96-2002 4Runners | 22 | 07-12-2003 01:11 AM |
