| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
how high does your truck sit with X lift
__________________
1994 Toyota Pickup 22re M5
1998 Camaro Z28 LS1 M6 1975 Kawasaki F7- IN PROGRESS 1997 Buick LeSabre- PARTING OUT |
#2 (permalink) |
Stock height up front is 13.5"-14" rim-fender:
http://www.off-road.com/trucks4x4/ar....jsp?id=398514 Add an inch to that for each inch of body or suspension lift.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
#4 (permalink) |
just the info i was looking for- ill edit the post after i measure for a 2nd time
front was 14 the rear was 15
__________________
1998 Camaro Z28 LS1 M6 1975 Kawasaki F7- IN PROGRESS 1997 Buick LeSabre- PARTING OUT Last edited by greatskiiiier; 07-03-2009 at 02:55 PM. |
#5 (permalink) |
just cranked down on the torsion bars- now it sits 14 7/8 on all all corners... now im ready for some 33x10.5s
__________________
#6 (permalink) |
Be prepared for it to ride like a lumberwagon
__________________
1992 4Runner, 3.0 V6, 5 spd, 33X10.5X15 BFG MTs on factory wheels with no lift |
#7 (permalink) |
Get a set of BJ/s , cheap mini lift, not as harsh a ride as the torsion crank. Lumberwagon is being kind.
#8 (permalink) |
by going up 7/8? i thought you were safe up to an inch- going in and out of my driveway the truck actually feels a bit more stable
__________________
#9 (permalink) |
Any cranking on the torsion bars will stiffen up the ride. Not saying that it is not safe, just saying that it is going to ride alot stiffer. If you buy a set of ball joint spacers you can actually relax the torsion bars a bit which will make for a lot better ride than cranking the torsion bars.
__________________
#10 (permalink) |
driving the truck today and it feels the same- i even joked to a friend that you guys must only drive BMWs because even after "stiffing up the ride" the truck is smoother than most vehicles that ive driven
__________________
#11 (permalink) |
I cranked the torsion bars on a dodge dakota I used to have after I got new torsion bar keys. The truck felt no different at first, but after a couple of weeks of driving it I felt that it rendered the truck almost undriveable.
__________________
#12 (permalink) |
if you crank m, lower your tire pressure a bit (33' tires, 36 lbs )
#13 (permalink) |
Is there a stock spec for the rear fender - rim?
__________________
87 4Runner, 22re, 33MT's,4.88's and locked rear |
#14 (permalink) |
Be prepared for it to ride like a lumberwagon (KVRunner)
hahahaha
__________________
85 4runner tan, spooled rear 35's KM2 s chevy 63" TG skid plate,3in trailgear springs,12in 5125's,high steer,v6 brake upgrade and 1in master.TG high steer |
#15 (permalink) |
p.s 33x10.50" tires fit STOCK with no lift!!!
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 246,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic http://www.cardomain.com/ride/2572486 |
| Tags |
| 1992, 1997, 6, add, buick, dakota, dodge, high, keys, lesabre, lift, member, parting, torsion, toytoa, truck, v8 |
