How does a beadlock work? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-29-2007, 08:21 PM   #1
JulsTirn's Avatar
can someone please explain to me how beadlocks work?
Last edited by Lysmachia; 03-29-2007 at 08:43 PM. Reason: Changed title to be more descriptive
JulsTirn is offline   Reply With Quote
Old 03-29-2007, 08:33 PM   #2
MudHippy's Avatar
Beadlocks pinch the bead of the tire to the rim to help hold it in place when tire pressure is too low provide enough resistance. It is accomplished by bolting a locking ring to a rim that has a seating area where the bead of the tire rests, it's like a ring that's welded to the rim behind where the bead would normally be. The locking ring is basically a circular clamp, that grips the bead against this part of the rims.
MudHippy is offline   Reply With Quote
Old 03-29-2007, 08:41 PM   #3
Lysmachia's Avatar
Pretty much what Mudhippy said. I changed your title so you;ll get more accuarate feedback Julian.
Lysmachia is offline   Reply With Quote
Old 03-29-2007, 10:21 PM   #4
AxleIke's Avatar
Staun also makes a bead lock that does the same thing, but is mounted inside the tire, and can best be described like an inner tube on a bicycle.
It isn't exactly the same, but it is a tube you fill with air, and it pinches the beads on both sides of the rim.
Advantages: Balances easier, is techincally "street" legal, locks both beads.
Disadvantages: Expensive, doesn't provide rim protection like a ring will, leaving rims open to easier damage.
AxleIke is offline   Reply With Quote
Old 03-29-2007, 11:40 PM   #5
Elkaholic's Avatar
Quote:
Originally Posted by Ric View Post
good info. i never knew how they worked either, just i never really looked into one, but now i know
Dont know if you were bein sarcastic or not cuz of the smiley but if not that makes two of us!!!
Elkaholic is offline   Reply With Quote
1985 22r pickup, no spark but engine cranks sandyota 84-85 Trucks & 4Runners 5 11-01-2016 03:20 PM
*SOLD* 1991 Toyota Pickup DLX 4x4 5 speed 165k, fresh motor,lifted,clean! $6150 GreatLakesGuy The Classifieds GraveYard 8 09-04-2015 10:27 AM
Dash lights and interior lights wont work ashersullivan88yota 86-95 Trucks & 4Runners 12 07-28-2015 07:22 PM
Write-up: Converting forward shift transfer case to a top shift for crawl box crashburnoveride 86-95 Trucks & 4Runners 1 07-10-2015 07:39 AM
Changed transmissions now reverse lights wont work madxman21 86-95 Trucks & 4Runners 2 07-09-2015 11:26 AM
Tags
bead, beadlock, beadlockers, beadlocks, beed, disadvantages, dose, lock, locks, rim, rims, stuff, wheels, work, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
