help wheres the temp sender
Old 11-04-2011, 11:15 AM
EFI85's Avatar
Im trying to locate the temp sender for the gauge . my gauge is always sitting at a little under halfway and id like to check the sender because it never fuctuates even when the motor is cold . thanks guys
Old 11-04-2011, 11:16 AM
EFI85's Avatar
btw its 1985 EFI 22RE
Old 11-04-2011, 11:29 AM
snobdds's Avatar
It's on the intake manifold between the 2nd and 3rd piston. It will have a spade clip on it. Just look behind the thermostat housing and you should see it. Taking it off will require the removal of a few vaccum hoses, so note where they came from.
Old 11-04-2011, 12:00 PM
EFI85's Avatar
thanks !!! i found it but im thinking the gauge is the problem . i unplugged the sender and grounded the wire and the gauge did the same thing as soon as you turn on the key it goes to just under halfway and stays there . Im now considering an aftermarket gauge since im not sure if fixing the stock one is something i can even do ..
Old 11-04-2011, 12:19 PM
snobdds's Avatar
Well sounds like your switch is bad...gage gets it's input from the sender.
Old 11-04-2011, 12:47 PM
EFI85's Avatar
switch ??? what would you be referring to ? .
Old 11-04-2011, 02:37 PM
snobdds's Avatar
The thermo sender is basically a variable resistor switch. The resistance goes down as the tempature goes up. Basically the same thing as the thermo switch for the ECU.
I guess call it what you like as long as you know what it is...
coryc85
12-05-2015 08:42 AM
bradahman
10-01-2015 09:24 AM
Matthew Perez
09-28-2015 05:43 PM
rmill05
09-27-2015 01:43 PM
--Oz--
09-06-2015 01:06 AM
Quick Reply: help wheres the temp sender
