YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-31-2008, 11:06 AM   #1 (permalink)
Help diagnosing oil leak 3VZE
This has been a tough one. I get massive oil drips out the dead front of my engine. I've also been under there when engine is running and not seen a drop. It leaks more when oil level is full (probably higher oil pressure) but will also leak if I slosh it, ie brake hard, but the leak will dwindle the longer the oil sits in the truck and/or its level drops. I thought it was my oil pan gasket because there's a break in the gasket material that squished out. Problem is this sits right under the oil pump so it could also be the front crank seal or oil pump gasket dripping down. I asked the dealer if they could verify either one since they'd just done an HG job on it. They said they couldn't tell, but thought I had a leak at the oil cooler o-ring I was surprised they couldn't find a cup-at-a-time oil leak off the front engine but it shows you how fickle this thing is. Since I can't locate the exact source I figure I have three choices:
a) fix the PITA oil pan gasket and see what happens
b) fix the PITA front crank seal and oil pump gasket and see what happens
c) suck it up, replace them all whether they need it or not (170k on truck) and let God sort out the rest.
d)try some further testing strategies (ie put dye in oil, get a black light, smoke a joint)
Obviously, I'm looking for the cheapest most logical course. I'd also like to be able to park places before my only friend is the Exxon Valdez oil tanker guy. All suggestions welcome.
__________________
'91 4x4 V6 Pickup
'77 FJ40 Land Cruiser
saltrig is offline
Sponsored Links
To remove this ad, register today!
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Found the oil leak--oil pan removal? morrison 86-95 Trucks & 4Runners 6 12-31-2007 03:16 PM
Questions about oil pressure and oil pump replacement on 3VZE ThomasJ 86-95 Trucks & 4Runners 2 11-28-2007 04:39 PM
No Oil Pressure!!! Major 3.0l Oil Leak BAMF_CT2004 86-95 Trucks & 4Runners 9 12-03-2006 06:01 AM
Oil Leak near the Oil filter with pics Myron 86-95 Trucks & 4Runners 6 09-26-2006 03:11 PM
Disappearing OIL, No Leak, Use Heavier Oil? alohatiger Maintenance & Repair Archives 0 09-03-2003 09:03 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
