| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Hard start when warm?
#2 (permalink) |
Is this solved yet?
Lots of ideas but not sure how many are relevant. The symptoms to me say "flooded" by that I mean excess gas lying in the bowl on a carbureted vehicle and yours would be fuel injected. However follow along with me... When a no start occurs there must be a problem with either spark or fuel. So can you verify a spark to any plug when this happens? If not do so-have a friend do the crank of the ignition key while you pull a plug wire to check it. If you are not capable of doing this yourself then take it to a qualified mechanic. We can go on from there but I wanted to see where you are at on it. I am an accountant but can certainly talk you through this. Hardly anyone cruises newbie tech so don't be intimidated to post on the main pages....
__________________
99 4Runner SR5 4wd 3.4/5 spd- Fact. Rr. Locker/Diff Breather Ext. Old Man Emu lift springs- 881 fronts/890 rears O/M/E shocks- N91s fr./N86 rr. All Pro Off Road welded sliders-prevent body damage! ARB"Taco"bumper/Gamiviti clear lenses/Hella 500s Redline Tuning hood struts/Bushwacker Extend a Fenders all my photos are over on Facebook now-I gave up on photo hosting sorry.... http://www.facebook.com/album.php?ai...5&l=5795132731 |
#3 (permalink) |
i had the same issue w/ my vehicle and it ended up being the coil pack. it would start fine then after i would shut it off it would not refire for a little while. after i replaced my coil pack it seems to be fixed.
#4 (permalink) |
I agee check coil pack and check timing.
#5 (permalink) |
Try the feul pump test jumper and see if that helps (or not):
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump If it helps, troubleshoot why the fuel pump is not getting power during warm starts.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs r.c.brown@ieee.org TruckEditor@tlca.org Project: 4Crawler 4Crawler OffRoad Gettin'Off 4WD Club |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| hard warm up | fatrick24 | 86-95 Trucks & 4Runners | 0 | 12-10-2007 07:03 AM |
| Hard start when engine warm/hot (long/detailed) | erkinne | 95.5-2004 Tacomas & 96-2002 4Runners | 20 | 07-28-2006 10:10 PM |
| 92 4x4 3.0 - Hard to start when warm | Back40 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 08-05-2004 06:36 AM |
| 92 xtra cab 4x4 3.0 - Hard to start when warm | Back40 | Maintenance & Repair Archives | 0 | 07-12-2004 12:00 PM |
| Hard Warm Start | cratz2 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-05-2003 10:41 AM |
