gear ratios
gear ratios
i need a front differential,, my shaft is hanging out of it. 1994 toyota pickup v6 dx cab. automatic. i call for help. and they ask me for gear ratio. where do i find it?
so what i have learned so far is that the front differential is also called the 3rd member, is that correct? and when i try to find parts do i ask for 3rd member or differential?
On your door jamb, you can find the axle code. It will read:
C/TR/A/TM
Means color, trim, axle and transmission, or will look like:
030/F41/G258/A340F
So your axle code would be a G258. Now calling the dealer can net you an axle ratio, but I have used this exact procedure and twice, it was wrong! So be warned. Based on what I have seen, you should have the 4.88 if you have ther large 31" wheels as stock.
I suspect you mean the RF axle stub. If its popped out, pop is back ASAP or it will destroy the carrier. DO you have a lift? These can pull this stub shaft out. Its only held in place with a circlip. Pop it back in and fill with fluid.
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
