| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
front axle
#2 (permalink) |
ive seen a bunch of them done. fj80 axle is good because it has an elocker already intalled in the third member.
#3 (permalink) |
if it was free it probably doesn't have the elocker. If it doesn't somebody got a sweet deal. It will be a great set up, if you are gonna go leafs you will need to swap out the coil mounts. Add a set of Longs to it and you should be golden...of course make sure the Front R&P matches your rear...
__________________
~Robb '81 Trekker The B4Runner Build TREKKER Forum Mini FAQ/Misc Ideas Thread **TRY THESE SEARCH LINKS**
GOOGLE FOR TOYOTA WEBSITES LINK TO ONLINE FACTORY SERVICE MANUALS Drive a real 1st Gen Wheel Responsibly, Don't Screw It Up for Others |
#4 (permalink) |
The differential on a FJ80 is the same hi-pinion that people put into the mini truck axle and going forward it is stronger than the standard mini differential. They are both 8" ring gears. The main problem with the axle is if you run leaf springs the slee high steer doesn't work and you end up with a bent drag link and the tie rod in the stock location under the differential. If you are going with coils it should be a nice front axle. The FJ80 is 63.5 wms to wms.
If the axle you have really has a bigger differential it is probably a FJ60. It has a 9.5" ring gear and is 58" wms to wms. The FJ60 uses the same high steer, knuckle, birfs, etc.. as the min truck axle. It is basicly the same as the mini truck axle except it is a little wider and has a bigger differential. The rear FJ80 differential comes with a e-locker which will fit into the Fj60 front.
__________________
1990 4runner, 22re, R151, 4.7, 5.29s, E-locker front, Lock-Rite rear, 37" MTRs, 51" rears all around Trail Reviews http://www.gentryoffroad.com Toyota Factory Service Manuals http://ncttora.com/fsm/index.html |
| Tags |
| 1990, axle, diffeential, differential, fj60, fj80, front, fsm, high, landcruiser, steering, tacoma, vs, wms |
