| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
formula for figuring out what gears you have
__________________
Concrete is the cancer of our land,just give me dirt... |
#2 (permalink) |
its on the door pannel sticker.
if its been swaped, well you have 2 options. count the times to spin the drive shaft for 1 turn of a wheel. or vise versa
__________________
94 EX cab, 5speed, V6, locked, ARB bar, NWOR headers 92 4runner, auto, V6, OME suspension, Downey headers |
#3 (permalink) |
what if the truck was regeard.
__________________
#4 (permalink) | |
Quote:
Have somebody you trust your life to slowly move the car, and count how many times the driveshaft spins with one revolution of the wheel.
__________________
:Marko: Supercharged 98 4Runner SR5 4x4 3.4L 4" Deckplate :: TrueFlow Air Intake System :: Magnaflow 18" Muffler w/ Resonator XM Satellite Radio (Roady 2) :: Autometer Boost Gauge :: Color Keyed Spoiler TOYOTA|moving forward
#5 (permalink) |
:pat: :pat: did'nt see that I'v been
__________________
#6 (permalink) |
Did it, about 2 1/2 revs. in the rear and about 2 1/4 revs. in the front. Whats the gearing?
__________________
#7 (permalink) | |
Quote:
And if the front and rear aren't the same don't use 4wd until you get them matched. |
#8 (permalink) |
The other option is similar, but doesn't require moving.
If you have a NON ADD rig you can lock one hub, have the truck in 2wd and spin the front drive shaft and see how many times it takes to get the CV to spin once. You can also firgure it out by RPM in 4th(5spd) gear at say 50 miles per hour, but you will have to know the rolling radius of your tire.
__________________
-John '05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600 2003 SR5 4Runner, V6 4WD. 1" cornfed lift Previous Toyota's '92 Red Truck NALA Speed doesn't kill, its the sudden stop that hurts. |
#9 (permalink) |
dumb question, what is (ADD)?
__________________
#10 (permalink) |
Automatic Disconnecting Differential
It's a vacuum operated solenoid that disengages the passenger side axle from the diff. There is not really anything as "ADD hubs" - there's a splined plate that locks the hub to the CV axle constantly, so as long as the truck is moving, the front drivetrain is all spinning
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks! Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R 96 Impala SS: My own personal cop car Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place Stop with the mods and get on the trail! Pix at www.4wheelingoh.shutterfly.com/action |
#11 (permalink) |
how would I know if my front diff is (ADD) ?
__________________
#12 (permalink) |
this would go a lot better if you searched a wee bit.
faceing the front of the truck look under it. if you see this big thing attached to the drivers side of the diff with wires and hoses comming from it that looks like the pic in the box that says w/ADD well then you have ADD
__________________
#13 (permalink) |
Sorry, I was just a little confused. My truck is a solid axle. Thanks for all the help everyone
__________________
#14 (permalink) |
Well if its a SFA you can't do what I meantioned anyhow, cant see the birfields turn
BTW: What is your truck?
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| need help figuring out trailer wiring issue | wallstrum | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 03-28-2009 10:52 AM |
| Vacuum Lines Ahoy!!! Need some help figuring what goes where. | Kyle95sr5 | 86-95 Trucks & 4Runners | 33 | 02-10-2007 04:52 PM |
| Need some help figuring out if 285's will fit fine... | thehoerunner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 04-17-2006 07:56 PM |
| need help figuring out power of amp!? | Mac6135 | Vehicle Audio & Home Entertainment | 4 | 05-16-2005 04:09 PM |
