Few questions for a first time owner
Old 06-03-2012, 09:45 AM
94_yota_4x4's Avatar
ok i'm new to the toyota world, but i am very mechanical. i just have a few questions and have not found a whole lot of answers. i have a 94 x-cab 22re 5 speed 4x4
1. is the ifs worth keeping? it is my daily driver but i want to put 35's on it.
2. what gears would i need to go with 35's?
3. how hard is the solid axle swap?
any help on these questions would be greatly appreciated like the title says i am a first time toyota owner but this is not my first 4x4
Old 06-03-2012, 10:15 AM
85TurboRunner's Avatar
If you haven't found a whole lot of answers to those questions then you have not searched at all.
Old 06-03-2012, 10:31 AM
runs-on-4's Avatar
google knows all
Old 06-03-2012, 12:09 PM
i have not seen a whole lot on the ifs and i see people talking about 5.29 gears there should be no reason to go that extreme for 35's
Old 06-03-2012, 12:23 PM
runs-on-4's Avatar
start here
http://www.bing.com/search?q=sas+vs+...=5-10&sp=-1&sk=
529s is not extream with 35s when you got 105 horses at the crank
Old 06-03-2012, 12:35 PM
I plan on a few tasteful mods before the lift and 35's i was only thinking 456 gears.
Old 06-03-2012, 12:40 PM
I run 5:29's with my 35's. 4:56's won't cut it.
Old 06-03-2012, 12:44 PM
What kind of gas millage do you get? I ask because in about a year ill be going from alaska to virginia for school and i would like it to not cost me an arm and leg
Old 06-03-2012, 01:30 PM
What are some options as for lockers and what would i search under? I dont know what size axle it is
Old 06-03-2012, 02:53 PM
I currently get about 18mpg. My truck is an 85 xtra cab 2wd converted to 4wd with a stock reman. 22re and 5spd transmission.
I have a lock right locker in the front axle and a full detroit out back.
Old 06-03-2012, 03:08 PM
are you still ifs? and what gear company did you go with?
Old 06-03-2012, 03:15 PM
StewsRunner's Avatar
I stay stick with IFS. No offense but I feel like if you are asking those big bulky questions, you shouldn't need to do an SAS.
Old 06-03-2012, 03:24 PM
i have owned a solid axle truck before it was just a bronco and it was already done before i bought it, i didnt know what i was really buying at the time then i sold it and when to sports cars and now im where i need a truck and im starting a build of my own and im used to the power of a v8 so compensating with gearing and lifts is not my specialty
Old 06-03-2012, 04:18 PM
I converted a 2wd truck to 4wd so I had to cut out all the IFS junk and throw in a solid axle.
I bought complete 3rd members from Marlin Crawler. They come all set up with the gears and lockers installed. All you have to do is put them in your axle housing.
The gears are Yukon brand.
Old 06-03-2012, 04:24 PM
So if i decide to hold off on the tire size and go 33's should i still go with the gearing for 35's and do the front and rear gears need to match?
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: Few questions for a first time owner
