YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Newbie Tech Section
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-08-2008, 02:48 PM   #1 (permalink)
A few newbie questions.
I'm not trying to sound dumb but , I have afew questions. My truck is a 89 4x4 with a 22re, 5 spd. , 134,000 miles. I have had the truck for a while and haven't driven it much because I had a company truck. The a/c has been bypassed , to me it looks like some of the smog equipment is gone and there are some things unplugged. The main thing is the o2 sensor just below the exhaust manifold, it's unplugged. I have looked for the other side to the plug and I can't find it. Also, i have 2 O2 sensors and they are both bfore the cat. None after the cat. Can I wire the front O2 sensor in with the back ? There haven't been any codes with the front O2 sensor unplugged. It just runs like crap. It also has a little black smoke coming out of the exhaust when I rev it up. I pulled the plugs and they look like it's running lean. I'm going to have a buddy check my fuel pressure and timing this weekend. I have replaced the plugs, wires, dist.cap, rotor, fuel filter, air filter.I have also cleaned the TB and the MAF and ran some seafoam through it. As soon as I can afford it I'm going to replace the coil . Any other ideas why it would run like crap? My mileage dropped. Any ideas about the O2 sensor? Thanks for the help.
89trknwby is offline
Sponsored Links
To remove this ad, register today!
Old 05-09-2008, 06:31 AM   #2 (permalink)
elripster's Avatar
O2 sensor will make your mileage drop. When they fail, the engine defaults to rich. All O2 sensors are upstream from the Cat so that's Ok.
You might make sure your CEL (check engine light) doesn't have a burned out bulb because it should be sending an error with the sensor unplugged.
I have the 3.0 so I hope that someone will 4 cyl experience will chime in. However, you can check the FSM link on the 86-95 page and it will give you more particulars.
Frank
__________________
1994 4runner, 3.0, auto, 5.71's, Truetrac (rear), 33's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos, Marlin rear bumper.
www.sdori.com
elripster is offline
Old 05-09-2008, 10:25 AM   #3 (permalink)
john rumbo's Avatar
Send a message via AIM to john rumbo
you mike check under drivers seat below the truck some body possibly change exhaust man before to a older one 89 4 runners has o2 sensor under driver seat outside 86 had a sensor on manifold check if yours is hooked up to the tailpipe under the floor when i origly changed my engine had 1 bare 02 sensor on manifold and it always would lean out and get hot, wireing somewhat different decided to do swap instead of dealing with real problem beleaved maybe different computer
__________________
bigblockyota 884runner chevy 454 fuelinjected fullsize chevy dana 60 axles 14bolt rear 5.38grs spools frt,rrear 4wheel disc conversion tur400 trns 203 dbler 205 tranfer aprox 8-10 inch lift 37inch tslboogers 3inch magnaflow exhaust msd ingn aluminum rad ,flex fan 56 , inch spring conversion w8000lbcomp winch and bumper
john rumbo is offline
Old 05-09-2008, 10:40 AM   #4 (permalink)
Staff
aviator's Avatar
Some of the trucks had two O2 sensors one before and one after the cat... why I don't know... might have been some thing to do with Kali. emmisions...
sounds like the PO did a frankenstein on the exhaust system...
in this case I'd almost want to bring it to a good dealer for a diagnosis...
or else a toyota specialist shop in your area...
__________________
Silver 1994 Hilux Xtra cab 4x4 3.0
K&N cone filter, ported MAF, advanced timing, oversize exhaust, free flow cat, "rumble" muffler
custom covered SR5 seats, map lights, factory AC
tv4184 style black interior conversion started
mods to come... header,
custom centre console, stereo upgrade
tinted windows
Founding member 1972TLC fan club
Toyota Hilux... Get in or Get out of the way.
aviator is offline
Old 05-11-2008, 11:23 AM   #5 (permalink)
thanks for all of the help. I checked and the one just before the cat is hooked up. I looked in the Haynes manual and the front O2 and the back O2 sensor appear to be connected somewhere . At least it looks that way i the wireing diagram. Thanks again.
Old 05-11-2008, 11:37 AM   #6 (permalink)
foot0069's Avatar
Here's a great link to use for troubleshooting. Most of the stuff shown will aply to your truck. I have a 91 and it only has 1 O2 sensor, it's in front of the cat. I'm not knowledgeable enough to talk about different model years. But I bet if you took the vin # to the dealer they could tell you if yours is federal or cal emissions compliant, and whether you should have 1 or 2 O2 sensors. You say that you think part of the smog gear is missing. If so that can surely mess with the way the truck runs. It needs all that stuff to let the comp do its job for running. X2 on taking it to a pro.
Jim
Oops Left out the link http://personal.utulsa.edu/~nathan-b...sm/engine.html
And here'sthe index for the whole book http://personal.utulsa.edu/~nathan-b...fsm/index.html
foot0069 is offline
Old 05-11-2008, 05:04 PM   #7 (permalink)
thanks for link.
Old 05-12-2008, 02:56 PM   #8 (permalink)
elripster, Iwent out and took the dash apart and found no bulb in the check engine light. I put one in and is does have some codes. I can't tell what the hell they are so instead of miss reading I'm going to run it to advance autoparts later. thanks for the tip about the bulb. I'll let everyone know what the codes are. Thanks again.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
another newbie w/questions mrNatural Introductions & New Arrivals 0 11-11-2007 05:47 PM
Few newbie questions blueyoda Newbie Tech Section 2 11-29-2006 07:26 AM
Newbie has some questions E30M3Pilot 95.5-2004 Tacomas & 96-2002 4Runners 18 06-01-2005 01:52 PM
Newbie questions mbeck 95.5-2004 Tacomas & 96-2002 4Runners 7 08-04-2004 10:00 AM
Newbie here! Have a few Questions? TurboToys 95.5-2004 Tacomas & 96-2002 4Runners 1 11-25-2003 09:32 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
